Lanier ld 228c says printing will begin after warm up, but it never warms up. Tech says hard drives are bad and need replaced. he put new ones in but still did not correct problem.
  • wallan May 11, 2010
    Does the printer show any service codes? IE SC545?
  • Office Equip... Master
  • 1,316 Answers
Check and measurement the fuser unit components(heater lamp,thermistors and thermalswitch) and check the toner quantity in the copier.If not toner the machine not start to working.
Posted on Oct 04, 2009
SOURCE:
How can I get A Lanier LD-620C parts manual
The LD-620 appears to be a Ricoh Aficio MP-C2051 or C2551.
You should be able to find a parts list on the net. Whichever one looks the same as your lanier (who don't make anything) will be the one.
Good luck
Oct 03, 2014 | Lanier Office Equipment & Supplies
How can I connect a Lanier LD430c to a Windows 8 computer so that the scanner work
Lanier doesn't seem to have specific drivers for windows 8.1, but you may be able to use the windows 7 drivers, here:
http://www.lanier.com/downloads/driverFrame.aspx?path=http://support.aficio.com/bb/html/dr_ut_e/lan_u/model/e_3000/e_3000en.htm
Sep 11, 2014 | Lanier Ld 430c With Feed, Bank, Print,...
Warm up please wait......happens for a long time, finally stops at ready and am able to print. After print job printer goes back into the warning up cycle again..for a long time. I have noticed that the...
Dear
This problem is due to fail or low supply of high voltage. The HVPS and LVPS is one card. try to clean the high voltage contact points and paths. the warm up time will be reduced. Otherwise you need to replace it. Other things you have experienced are normal.
Thanks.
Nov 20, 2012 | Samsung SCX-4725FN All-In-One Laser...
Sc 544 lanier ld 122
CALL FOR SERVICE YOU WILL NEED NEW THERMISTORS NEW THERMOSTATS AND MOST LIKELY HOT ROLLER,CLEANING ROLLER AND HR BEARINGS COST OF TIME AND PARTS WILL BE 400 TO 500
May 17, 2010 | Office Equipment & Supplies
Lanier copier ld145 locked up, code is sc546
Fuser warm up problem. Cause needs to be fixed and then code can be reset in service mode by a tech.
Jul 29, 2009 | Lanier Office Equipment & Supplies
Lanier 5645 SC322 Error
It's most likely your Laser diode (LD unit). You're going to require a tech...see the posts the following link for the same problem. It's for a Ricoh model, but your machine actually is a Ricoh Machine (Ricoh owns Lanier), and is virtually identical to this one -just a generation older.
http://www.fixya.com/support/t1936988-sc_326_322_329_in_af2045
Apr 07, 2009 | Lanier Office Equipment & Supplies
2000 jetta gls
some times new thermostat are bad . try a new one but hotter 195* or better
Jan 14, 2009 | 2000 Volkswagen Jetta TDI
Lanier copier 7313 AG
The clutches arnt too bad putting them in however... I own this model as a home copier but parts are hard to come by and to get a tech that knows how to repair is harder.
Sep 18, 2008 | Lanier 1205 Copier
47 people viewed this question
k24674
Marvin
Marvin
