Fridge is not cooling, freezer not freezing, has a buzzing sound coming from the sealed compressor unit, or 'on - off' relay mounted on the side of the sealed compressor unit.
With any luck this is you overload and relay
it is the plug on the actual compressor, this is very easy to replace, if you replace it and it does exactly the same thing its your internal relay and your compressor is done....
Testimonial: "thank you...I removed the relay/regulator to find it rattled and found burnt marks inside. I found them online, am waiting its arrival now."
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
