We accidently ran our coffee maker without the filter in place; what a mess. I got it all cleaned up; used q-tips and a little wire to get the coffee grounds out of all the nooks and crannies and got it running again. But now it is leaking coffee into the grounds drawer; makes me think I dislodged a gasket or something. Advice?
On top of the Brew Group is an arm that dispenses the coffee into the cup. Did you remove the arm? There are two screws that secure the arm to the top of the Brew Group. When you remove the two screws you'll find a spring that's inserted into a hole. Be carefull. There is a ball below the spring in the bottom of the hole. Don't loose it. At the top of the hole where the plate for the arm mounts and covers the hole, there should be an o-ring gasket. If you removed the arm while cleaning and didn't put the o-ring back in, you'll get this problem.
Here is a tip that I wrote
that will give you some things to try that will help you get your
Keurig coffee brewer working again.
Keurig
Coffee Brewer not making a full cup of Coffee
heatman101
