I am guessing that the parts inside of your mixer are starting to wear out and your mixer is starting to die on you and you should buy a new one and the motor could be going bad too.
Hi, This is very likely to be a dirty key contact.
If the loud key is not touch sensitive or by turning the touch off, if all the keys are the same volume then this points to a dirty key contact.
All the best, Chris the Fader.
In a word, NO. Changing type of strings might make it a bit louder, however the sound quality would drastically change if it does. Best to leave alone... Get a small amp, portable battery if needed... OR there are headphone amps that are designed to be used for practice.
The amp has a failure. One side of the power amp is starting to draw excessive current to the point that the filter caps can't sustain the current so the ripple starts to be heard in the speaker. Continued use MAY burn up the speaker by sending DC through it as well as causing additional damage to circuit boards, etc..
Besides checking balance, cables and length of cables can cause that. If cable is weak, or if one side is longer than the other, you'll get that effect
This is far from normal. What may be the problem is a component on the circuit board itself. You may have to take this to someone who has a multimeter to test and see which one it is (this may take a while, since there are a LOT of small components). If you don't want to (or have the money to) do that, you can just set the balance to the opposite side of the louder speaker until it sounds even out of both channels. Eventually, though, something will have to be fixed.
Sorry, the fan is thermally controlled and USUALLY will run at low speed when unit is lightly loaded. In hot weather or driven hard it will run faster and louder.
Whatever you do, do NOT block airflow... these are a dual 400 Watt continuous amp (600 a side peak) and they need to breathe !!!
If you can duct cool air to it, that will help. You could also try sound absorbing baffles while maintaining adequate clearance for airflow.
You have had a pre amp or final amp go out. If you have any electronic background, you can open the unit up and compare the voltages on the side that is working and find the problem with the other side. Most of these stereo boards have the same componets one side that is on the other. Hope that makes sense. Hope this is helpful.
