SOURCE: call forwarding?
Contact your network who will be able to turn off/ reset your voicemail. There may have been a few network faults that have meant the settings dont match what it should be, this is an easy thing for them to check and correct .
SOURCE: call failed error for outgoing & incoming calls
Press call logs-Press menu-click on Options-General Options-Restrict My Identity(It should be never)-save and ok.For text message your message center no has been changed so call your service provider and ask for message center no and update in your device.To update Press menu-select options-SMS-Service center-change the no and save it.After saving do the hard reboot.
SOURCE: Can't call, recieve calls, text or recieve texts
ok... i started having the same problem after i got a battery saving app that controls the data input/output. well i just uninstalled. i think it might have screwed with the radio network whatever it is. so ima take it into the store soon to see if they can fix it if all else fails
