HTC G1 Logo
Posted on Oct 02, 2009
The screen isnt cracked..the protective glass on the outside is cracked..how do i replace it
Anonymous
Level 1:
New Friend:
  • Contributor 84 Answers
  • Posted on Jul 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
84
Questions
0
Helped
20700
Points
99
Do you mean the touch pad glass has been cracked ? You can buy a new one from here: http://www.ownta.com/original-htc-g1-cell-phone-touch-pad.html
1helpful
The outside of the window on my front loader GE washing machine (model GFW450ssM1WW) cracked in 5 places.
If the plastic is cracked, you only need the frame and you can transfer your glass dome to it.
A lot of money for a plastic ring! I would fill the cracks with Super Glue Gel and fill the back with Liquid Metal Epoxy.
https://www.geapplianceparts.com/store/parts/spec/WH46X25524
The glass is obsolete!
https://www.partsimple.com/15011048-amg-n-8.html
How can you fix a pandigital tablet screen that is cracked?
Sounds like a rough one. Repair the crack? @ things ... Replace the glass and or the screen.You do not want to get any glue or used for that purpose. The glass is to protect the screenso, it would be best to look into replacing the glass. It might be part of the screen itself.
Good Luck-Ned-
1helpful
3answers
The screen looks cracked and multi colored but the actual glass isnt broken or cracked
Your LCD/monitor is cracked from the inside. There are several things that can cause a screen to crack from the inside. The two most common are pressure on the screen or dropping the machine. Sorry, but it is irreparable. You need to buy a replacement.
5helpful
Vtech Mobigo screen cracked can it be repaired?
If this device is still working however the crack is small or not deep enough to affect the picture quality of the device, buy a cheap glass repair kit. This will not only fill the crack but ensure the glass stays protected and will look new. Also, after using the repair kit, be sure to use a anti-glare shied to further protect the screen.
If the screen is cracked to a point where the image is blurred, distorted or the colours are not accuratly displayed, unfortunately the glass will not be able to fix without speacialty parts specific to that device. If this is the case, I suggest you visit the site provided at the bottom and follow the steps indicated on the page.
Glass repair kit and demo:
http://www.youtube.com/watch?v=1FwIC7-bttk
http://www.amazon.com/Fix-Flat-Windshield-Do-Yourself/dp/B000EA5WLS
Replacement Parts:
http://www.vtechkids.com/support_replacement.cfm
Hope this helps. Good Luck!
4answers
I have a sanyo 50'' lcd tv model dp50749. It has a cracked mirror glass in the corner and isn't visible when the tv is on but only when its off. can i fix this myself and how??
No, I'm sorry, but the technology to fix the actual lcd SCREEN is not out there yet. The reason you don't see it when it is off is because it is actually the inside of the screen that break, unlike plasma tv's, when they break there will be actual glass fragments. If the broken area is to big to deal with, then the options are; buying and installing a new screen (alway about the same price off the tv new, or more), you could sell the insides of the tv on Ebay for example, they are very much needed parts (powerboard etc)....Those are about the only options, unfortunatly...If selling the powerboard, you shopuld be able to get around$100 for it...
Once again, I'm sorry I didn't have good news, but please rate if it was usefull, thank you!
2answers
Screen appears to be cracked but glass on the outside not broken.
Hi.
If the outside panel is intact, then the crack may be on the LCD panel, located beneath the protective glass panel.
If the Sat Nav is less than one year old, then the replacement will be done free of charge.
Contact TomTom at the number listed on manual to arrange repair.
Here the repair procedure : YouTube - TomTom Xl lcd replace
Cracked screen can it be fixed
No..the Glass Display Panel ... If cracked... Cannot be repaired.. it is not just a piece of glass, it is a layered panel with pixel grid panels along the top and sides that show color to the grid on the screen panel and go all throughout the display ..
If the Crack ocured behind the display panel on the plexiglass protective panel, that can be replaced... but No Not The Front LCD Display Panel.
Panasonic HDTV 1080i Screen
Usualy Panasonic have 3 layers on the screen. From inside to outside is: fresnel, lenticular and protective. If only the one from outside is broken don't wory. It;s just protective and the film it's just a filter to improve the black level. You can use it like that but be carrefull because the lenticular it's not protected anymore and if you scrach it ... And do not try to clean it with anything else just dry rag.
Top HTC Computers & Internet Experts
Paul Carew
john h
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
