I lost my manuel for the innovage jumbo remote. I need the codes for a philips tv. Can you please help?
I have a sharp tv and lost my booklet for the codes can you help it an innovage universal remote thank you
I need a code for an emerson tv
I have found the iWave, Innovage, and generic "JUMBO" are the same remote.
Here is the link to the manual. It looks like it has a easy to do auto-search button.
http://www.vat19.com/dvds/jumbo-universal-remote-manual.pdf
Good Luck
Need code
Orion tv is 192
For Visio and the Jumbo Remote - 004 worked for me.
DoctorBill
RE: Solution #2: Guest; "SCAN INDTRUCTIONS" ... Thanks, the INNOVAGE -Jumbo URC had my Toshiba TV and my LG combo DVR-VCR combo codes included. I re-confirmed these codes by your correction to the listed CODE SEARCH SCAN instructions. Then I used this method to locate the proper code for my Direct-TVR R15. The Jumbo URC tried about 20 minutes or so (Blinking with each code it found) before it finally gave up. A set of codes were included for Direct-TV. None of the listed codes worked for my R15 device. The Direct-TV website list other manufacturers for many devices, but my R15 is listed under Direct-TV only. HELP! Jumbo URC codes for D-TV R15!!!
I need codes for a panasonic tv
I have a innovage jumbo universal remote do you have the code for a baird lvd tv
I have a Fisher TV could you give me the code?
Remotecodelist.com/remotes
Try this website, i specifically found the Innovage jumbo remote codes here, but if you scroll down it has several remote codes listed by manufacturer of the remote. Hope it helps!!
http://www.xdiv.com/remotes/
My Morotola cable box was not listed in the manual. So, I had to scan for the code. Problem was, the SCAN INDTRUCTIONS in the manual were INCORRECT. Evidently they were written for a prior version of the Jumbo. They say to press the ON/OFF button "REPEATEDLY" to scan from one code to the next. NOT SO! Only press it once to start the scanning sequence. The red LED will blink all by itself for each code attempted. Wait for the selected device (TV, VCR, etc.) to power off, then press the ENTER button IMMEDIATELY, before it steps to the next code. This captures the last code attempted, the one that shut down your device.
If your LED does not blink repeatedly all by itself, then you can assume you have an old versin of the Jumbo. In that case, follow the instructions and press the ON/OFF button yourself for each new code you want to try.
Remote control help sites are full of requests by frustrated buyers looking for help. I gave the Jumbo a low rating because of the erroneous manual and the incomplete code list.
I can't find my instrushuns
code for polaroid lcd1511-tlxb
i want to use this sony remote rm-ez2 on my phillips tv..is it possible to do this? or does it just work on sony tv's? i need codes if there is one..
i have the jumbo remote and have a proscan tv don't have code
code for a poloroid dvd player
was using RCA and Jumdo remote with my old Hughes Directv receiver.
this receiver died and was replaced with Directv R12. model. Can't program other remotes for this receiver. Need codes or arem other remotes incompatible ?
i have a sharp tv an i lost my manual book to program my tv can you please send me a copy of the manual book please.
i actually have my manual with all the codes so if you need help....just ask me
I have innovage jumbo remote but do not have code my tv is a elecrohome.
I have innovage jumbo remote but don,t have code . my tv is a electohome.
I have the same remote and idk how to program it and i dont have the blooklet please help!!!
I have the silver innovage universal remote control, and I would appreciate it greatly if you could send me a copy of all the codes going to a Toshiba-SD-V393. I have been able to work th tv, but cant seem to run a dvd player. I greatly appreciate your time and service in this matter, SINCERELY; RON LEE MILLS
lost my code book for my innovage jumbo remote control
dont know how to save the code
I need code for Jumbo remote for a noika TV, can anyone help me?
sony tv need code
need code for samsung tv
Need code for directv hd dvr. Codes in book don't work for satellite. Thanks
Innovage Remote code needed for Vizio HD TV....can anyone help:
code for a Sabre sold at AFEES
i need codes
I'm in need of Innovage Jumbo Universal Control Remote Codes
I LOST MY CABLE BOX REMOTE BUT I HAVE A JUMBO INNOVAGE UNIVERSAL REMOTE CAN,T FIND THE INSTRUCTIONS ON HOW TO PROGRAM IT
I lost the manual to my Jumbo Remote, its Innovage.... ANd my tv is a TruFlat??? Or something rather..... and I need Helpp!
I need the codes for the innovage jumbo remote control, can any one help? Please.
I have a symphonictv and need the code. thanks
i need codes
cant find my tv
i need codes for my jumbo remote to connect it to a toshiba tv
I need codes.
i need codes for the innovage jumbo remote
i need the code for JVC tv. I lost my code manual for the universal jumbo remote
i need a code for orion large tv
how do i program a tv/dvd tv
It happened to me too - don't worry, you can find it all -
HERE!
Rate my answer :-)
Here is what you are looking for - universal-remote-controls.blogspot.com
i cant find my codes for jumbo universal remote innovage
