Help i got a jvc grd 53 i only used it a couple of times and it worked great untill 7 months of no use and i wanted 2 record but no picture just a load of lines going up and down the lcd , its got sound can u help please . . . . .
Have a look on the site http://www.convertmod.com, you will find your
happiness with this wonderfull software that converts .mod files and
that converts .tod files
OK, it is known problem of CCD Imager chip failure in JVC GR-D33 camcorder and ccd imager will be replaced to get live view for recording, lens cap message will disappear as well. JVC will repair your camcorder free of cost for same problem, click JVC CCD Imager Support for details. Thanks.
The problem with these units is the filter capacitors in the power supply. They should be removed and replaced with 25 v.dc capacitors...total cost for the capacitors £5. If you don't fancy doing the repair your self, perhaps you know of a good friend who can use a soldering iron!
The capacitors are 2200 micro farads radial mounting, 680 and 1200, all should be at least 25v dc working for a reliable recorder. The existing ones are prone to "leaking" and should never have been used...shame on you JVC!
1. Take out the tape - AND TURN THE CAMERA POWER ON 2. press the menu button (near the viewfinder) 3. Use he wheel on top next to the viewfinderto scroll through the choices 4. Choose "display setup" by pushing the wheel in 5. Choose "C. Rest" by pushing the wheel in 6. Turn camera off 7. Next time you turn camera on y ou should be able to view tapes and record. IT DID NOT WORK THE FISRT TIME SO I PUT MY FINGER IN TO TRY TO GENTLY PUSH BUTTON WHEN I TOOK THE TAPE OFF AND THEN TRIED SOLUTION ABOVE AGAIN, AND THIS TIME, IT WORKED. BUT PLEASE DONT INSERT YOUR FINGERS IN AS I DID TRY THE SOLUTION 2 OR THREE TIME IT SHOULD BE OK, HOPE THIS WORKS FOR YOU, THANKS AND CREDIT TO LABBER
Ditto - JVC KT-SR2000 backlight doesn't work (watched die yesterday), after 2 years, 10 months. Sadly JVC no longer represents quality. Note: Original JVC KT-SR2000 was a fire hazard - defective from start - overheated hardly describes it. BestBuy replaced first month.
