If the power cord can be removed via a plug on the unit you should test the power cord for continuity. This can be done with an inexpensive multimeter. The cord should be removed from the coffe maker and the wall outlet. Then connect one of the probes on the meter to one of the prongs that go into the wall. The other probe of the meter should be touched into one of the two holes in the other end of the plug. You should set your meter to read resistance or ohms. If the meter reads close to zero then one leg of the cable is fine. If it blinks a "1" that usally indicates an open connection on a digital multimeter. If that is the case then connect the probe to the other prong. Once this is done then you need to test the other prong.
Hope this make sense.
If you get continuity on both legs of the power cord then I can explain further how to test the coil in the coffee pot itself.
Bob Janelli
I’m happy to help further over the phone at https://www.6ya.com/expert/bob_62dfa2f81bb55288
Testimonial: "thanks for the help, I'll do the testing and let you know what happens."
Go to eBay look for Farberware parts.
I tested the power cord and it's OK. I guess I'll order the heating element.
Ben
