Hitachi Deskstar 7K250 80GB (hds722580vlat20) 80 GB Hard Drive Logo
Posted on Oct 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cloned hard drive "C" (WD 40GB) to A Deskstar 8oGB using external enclosure. When I remove the old drive and install new drive and boot up I get Msg drive 0 not found retry or enter setup. If I enter setup will BIOS automatically find drive 0 or do I need to do something?
Anonymous
Level 2:
  • Expert 329 Answers
  • Posted on Oct 01, 2009
Anonymous
Expert
Level 2:
Answers
329
Questions
Helped
98881
Points
918
There are few thing you ahve to keep in mind
there are two type of hard disk
1. IDE
2. SATA
As per your hdd capacity it should of IDE type.
Now there are two IDE slots on motherboard. One is Primary and other is Secondary
You can fix two hdd with one IDE Slot that mean you can fix up upto faour IDE hdd at a time
Now again there are Primary master and Primary Slave
and
Secondary Master and Secondary Slave
Now You have to examine what was the location of previous hdd
1 Primary Master
2 Primary Slave
3 Secondary Master
4 Secondary Slave.
Now you have to make a HDD master or Slave.
just in between data cable connector and power cable connector there is a jumper. that specify the master or slave. do reply me if it works well thanks
1helpful
The unit won't turn on... fry's on 8-17-2010...tooo much info to loose this is the 2nd, time that i have used it
You can still save your information if you remove the actual hard drive from its enclosure.
Simple as opening the enclosure, remove the hard drive then use an external hard drive dock - here
A hard drive dock instructions are here. Youtube: http://www.youtube.com/watch?v=OUrw9W3-FcA
and connect it to your computer for back up to a new hard drive.
A how-to can be found here. Youtube = http://www.youtube.com/watch?v=hQ_vjyvK28A
Let me know if this works.
Medion MIM2080 MD95408 Original 40gb hard drive has died. Purchased 80gb replacement. Have cloned WIN_XP_PRO from another device onto new hard drive. When laptop boots all you get is a black screen...
did you get all the files? most likely there is a corrupt or missing set of files in the cloned files
i suggest you either get a new hard copy (disks) and install from there or use linux (most linux OS's are free online)
2answers
How does a hard drive looks like? I'm getting a error msg saying that hard drive is bad!!
How old is your hard drive ? Hard drives eventually fail due to normal usage or it could be something else. You need to provide more information.
Doesn't boot
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Note that W.D. has a "Customer Loyalty" program. Buy a new W.D. disk-drive through the W.D. web-site, at a significant discount.
My 320gb external hard drive has stopped working. I have used it alot with my laptop, but i hadnt used it for about a month. when i plugged it in it said it needs to install device driver software, but it...
Try connecting it to a different USB port on your computer.
Try connecting it to a different computer.
If the problem persists, either:
* the USB cable is damaged,
* inside the enclosure, the disk-drive is not functioning
(although the lamp indicates that it is getting electrical power)
* inside the enclosure, the USB-to-disk-drive adapter has failed.
If the warranty is still valid, W.D. will replace it, at no cost to you.
If the warranty has expired, W.D. has a "Customer Loyalty" program; buy a new unit from their web-site, and you can get a discount, as a previous customer.
Or, open the enclosure, and remove the disk-drive, and temporarily connect it as a "slave" disk-drive in a desktop computer, to see if it is working at all.
Or, buy a new, compatible, disk-drive, and mount it into the enclosure, to make a "new" external disk-drive.
My WD external drive is plugged in, and my computer keeps saying that one of the usb devices has malfunction and is not being recognized. I have very important data on this drive. How can I fix this...
The problem may not be with the hard drive itself but with the interface between the drive and the USB port. The drives in most cases are fine if they have not been dropped or abused. The problem with external drives is usually the small circuit board that contains the sata to usb interface. Try purchasing another external hard drive enclosure and remove the drive from the enclosure you now have. There are guides on youtube to show you how to take one of those WD enclosures apart. Just install the hard drive in the new enclosure and load the driver files that come with the new enclosure. You should have a working external drive....as long as the hard drive has not failed.
IBM deskstar 120 GXP 40GB will only format to 22GB. Its an old drive setup in an external usb enclosure
sounds like you're trying to format with FAT 16 or 32 which limits the partition size.
Try formatting with NFS which has no limit on partition sizes
1helpful
I have just removed a IBM Deskstar (DTLA-307015) from my desktop and installed into a external enclosure just turned it on and it worked without installing any drivers. I want to know is this set up right?...
since you said that the HDD works you have nothing nto worry, that means you have installed it correctly. as for clearing it up suggest you do a complete format. when you plug in the USB the pc will assign a drive name to it. note it down. the right click my computer/manage/disk managment(from the left panel) right click on the drive you noted down & format.
3helpful
Cannot see drive letter for deskstar 7k250 in usb enclosure winxp
Add a letter for this HDD in "control panel\performance and maintenance\administrator tools\computer manager=ment\disk management"
2answers
Replace existing 40GB internal HDD in laptop with 160GB internal
Drag and drop the files from one drive to the other.
  1. Plug your new drive in
  2. Right click 'my computer'
  3. than open 'C drive'
  4. repeat steps one and two
  5. than drag the files from C' drive to new drive'
Top Hitachi Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
vince
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
