When was the last time the projection lamp was replaced?The projection lamp on the tv now,has not been replaced like a 1 1/2 or 2 years,tv been on and watches like 4 or 5 hours a day?The tv projection lamp life are over.Require a new projection lamp.
Please make sure that the video source is on and that the source input on the TV is set properly. I am thinkig that the TV is working properly but has no input signal to display.
check the solder around the area of the vertical IC. solder is either cracked or else cold. Cold solder appears as dull. Resolder anything that isnt shiny.
you have lookse connection on the video convergance amp ic
KIT10 $29.50 Repair Kit for Hitachi convergence Chassis DP-14G KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
This sounds like the solder joints on one of the convergence output IC's have cracked loose or the IC itself is defective and quitting when it warms up. The IC needs to be either resoldered or replaced.
hitachi ultravision will not turn on
