If your telephone rings when you are on a call you will have to go into programming on the system and set DND on Busy to "Y" it will be set to "N" at the moment hence your phone rings when you are on a call, be carefull if your phone is the only phone to ring on incomming calls if you get a second call comming into system when you are on a call there will be no audiable ringing on any telephone to aleart you to this second i/c call.
MANY TIME A PERSON DIALS WITHOUT REALIZING THAT THE ACCEPTANCE CODE NEEDS TO BE INSERTED FIRST THE Nortel T7316E?...If you want to
temporarily turn them off use do not disturb (feature 85, feature #85 to
turn Do Not Distrub off) Turning off the ringing permanently will require you to program the set. Programming is done on M7310,
...regards John
