New Bright Remote Control Toyota FJ Cruiser Logo
Posted on Oct 01, 2009
New Bright 19.2v batteries
I also purchased a couple of New Bright cars for my sons and when customer support did respond-they told me that the only place that still retails the 19.2v nicd battery was a place called "Pool Gear Plus"!? What's up with that? Pool Gear Plus is a POOL supply company. I guess I won't make the same mistake twice.
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Feb 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2752
Points
You can purchase batteries at any hobby store or buy matched cells to make a new battery pack
HELLO. I HAVE A NEW BRIGHT 2004 CADILLAC ESCALADE REMOTE CONTROL CAR THAT MY YOUNGEST NOW WANTS TO USE BUT WE CANNOT FIND THE REMOTE CONTROL FOR IT. I WAS TOLD THAT NEW BRIGHT DOES NOT SELL REPLACEMENT...
WELL I HAVE A CADILAC ESCALADE REMOTE CONTROL TRUCK CAME OUT IN 2004 BY NEW BRIGHT. I HAVE THE CHARGER AN BATTERY AN REMOTE I LET IT SIT AN NOW IT DONT FUNCTION I WANT TO BUY ANOTHER ONE
Aug 03, 2011 • Toys
2helpful
A few years ago, we purchased a very expensive Dell scanner. It's super important to a new Grandmama to send son's baby pictures to New Jersey via scanner. Son has been alienated many years. ...
It is unlikely that the streaks are caused by the light being too bright. It is probably a flourescent tube and needs replacing.you need to write the model number of the scanner to get this help.
1helpful
Where can I buy a battery for the DX-902 Lil Driver golf cart? My golf cart doesn't work, so the first thing I think might be wrong is that the battery doesn't work. The golf cart sat in our...
Dear kimbroberg2
My husband and I did the exact same thing for our grandson when he was 8 months old. We pulled the car out of the attic last night and the battery did not work. My husband called the manufacturer customer service at 714-256-9888. He was told that the batter was too old and would have to purchase a new one. My husband called around for the item description that they suggested and found a comparable battery at Interstate Battery in our hometown. Good luck. I know we were very disappointed when this happened, but there is hope. Hope this helps.
I bought a wowwee mr personality robot for my son for Christmas. It talks and responds with words, but it will not move. The remote also will not turn it on-only off even when the button is in the on...
should be under warranty
with receipt of purchase return to place of purchase
confusing instructions indeed
try using robot with the power source plugged into it robot wont shut down like it does on battery
reset button on robot base
point the remote controller towards the robot’s IR receiver so that he receives the signal properly.
You can turn off Mr. Personality from a distance using the remote controller; Table 2 describes how.
NOTE:
If you want to turn him on after having turned him off using the remote controller’s power button,
you need to restart him using the power button on the
robot (press it OFF and then ON again).
one online site offers a repair service
Manual WowWee Mr Personality Toy Robot
Mr. Personality - The Old Robots www.theoldrobots.com/images7b/Mr._Personality_Manual.pdf
Apr 28, 2017 • Wowwee Toys
My sons screen froze up and is bright green ... took battery out held down power key then replace battery ... went from loading a blue screen back to bright green - Samsung Impression NEW phone
If it's a new phone, take it to the place that you purchased from and have them check it out. Make sure you take your box, charger, and paperwork and receipts with you. Good Luck.
Prizm was left unstarted for one month in 100 degree temperatures. Unable to jumpstart. Battery was replaced but starter does not seem to have power. Lights are working. Any ideas? My son loves this car....
Go to Advance Auto and ask for a $15 battery. these are new batteries returned because the customer bought the wrong item. they have a 90 day warranty and are $15 to $20. or simply return the battery you just purchased, and exchange it but get it tested before you leave the store.
New bright 19.2v nicd battery problem
the battery isnt lasting because it needs to be fully discharged (drained) before it is recharged. (this is only for nicd batteries)
1helpful
2answers
I have purchased 2 remote controlled toy cars from Costco over the years. These New Bright batteris and charges last only a few charges, and then they go bad. I am disappointed. I will go to Walmart and buy a new battery and see if it works better, if not, i will return to Walmart.
3helpful
2answers
Don't throw away any NiCd power tool battery, Firestorm or Versapakbattery that does not hold a charge or does not give you the power youneed, you can get new life from your battery or device that containsNiCd batteries. icad batteries often die in such a way that they won't take a chargeand have zero voltage. This usually means they are shorted out bycrystal dendrite growth. You Can fix these shorted crystal dendrites by"Revitalization through Vaporization of Dendrites (RVD) Process".
You can get this guide from here
Photos are too bright, almost white....
camera makers would like to use flash lights as bright as the sun, so the flash is fine. the problem lies in the exposure time. continue trying different exposure settings. most makers provide these as pre-programmed settings while some offer manual fine tuning.
Top New Bright Toys Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Don A
Don A
Are you a New Bright Toy Expert? Answer questions, earn points and help others
