Nikon D90 Digital Camera with 18-105mm lens Logo
Posted on Oct 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nikon D90 stuck on manual focus mode.
I just bought a Nikon D90 a couple of days ago. I have been using both autofocus and manual focus, but this afternoon after setting the switch back to the AF (autofocus) position, the camera didn't respond.
I have tried a reset. I have also disconnected and reconnected the lens (which is set to focus mode), but it just doesn't want to get back into AF mode.
Is there something I'm missing or should I take the camera back to the shop?
  • Georgi Grozev Sep 14, 2013
    Well, same happened to me but after 2 years of usage. Is there another solution, and not taking it to the who? 'cause i live pretty far from any shop.
Anonymous
Level 3:
  • Master 10,865 Answers
  • Posted on Oct 01, 2009
Anonymous
Master
Level 3:
Answers
10865
Questions
0
Helped
3801719
Points
33142
DEFINITELY return it while it iis under warranty.
Is the Tamron AF08N700 auto focus with the D90?
Good morning. You have likely already gotten an answer to this, but yes, it will.
Unlike less expensive models such as the D40, D60, D3000 and D5000, the D90 has a built in autofocus motor, which means that all Nikon F-mount autofocus-lenses (except two for the rare Nikon F3AF) can be used in autofocus mode for all newer generation autofocus lenses like the Tamron 200-800. However, you may want to look around a bit, as Tamron has come out with a new 150-600 lens that is simply terrific (I know, I own one) and the Big Sig from Sigma is equally great.
FYI
Good luck.
tip
Getting Better Pictures From Your Nikon D90
I'm a professional PGA Photographer out here on the West Coast. I've been photographing for over 40 years. A few years ago, I bought a Nikon D90, after over 50,000 photos, I've came up with the conclusion that Manual Focus and Manual Shooting is the best. Program, A, S, Landscape, are all good, but, they are not consistence all the time. The same with Auto Focus, I can not tell you how many times I'd line up a photo of a Pro Golfer and my Auto Focus moves in and out of focus, and I miss the shot. So, now I use the Auto Focus to start and as soon as it's sharp, I reach over and turn my lever back to Manual for the shot and any refinement focus as well. Manual exposure is needed as well, as the Program modes will not be consistence from shot to shot. I meter the subject, take a test shot and change my setting manually. That way the exposure is the same. Hope this helps
on Mar 27, 2010 • Cameras
2answers
The Auto focus in my D90 does not work
Does it shoot in manual focus? In which autofocus mode(s) does it not shoot? Are you trying to focus too close, or on a subject with insufficient contrast?
HOW DO I SET MY CAMERA TO AUTO FOCUS
The D90 has three different autofocus modes. In the AF-S mode it will not shoot until it has focused. In the AF-C mode it will shoot when you press the shutter release button even if has not focused. In the AF-A mode the camera switches between the AF-S and AF-C modes so either can apply.Also, bear in mind that the camera doesn't really know what you're taking a picture of. It may focus on something other than your subject. If you're in the single-area AF mode then you control which of the eleven focus points the camera uses. In any of the dynamic-area AF modes the camera decides.For full details on how the various modes work, please consult your manual. You might also check out the Nikon D90 video tutorial.
Apr 24, 2012 • Cameras
Hi I cannot get my F80 to autofocus. I have tried all my lenses on my Brothers F80 and they all work fine on his camera. I only bought the camera second hand a few days ago and i'm 99% sure when the...
If the gears are stripped, it will require an experienced tech to repair.
That being said, there should be a small switch near the lens mount to switch between auto and manual focus mode's, be sure that that switch is pointing to A. When set to M, the little screw recesses into the mount so it doesn't try to engage, when set to A, it'll extend very slightly.
Also, Nikon has manufactured two types of AF lenses - with the motor in the body and with the motor in the lens, as with most newer lenses. Your camera should have a small screw on the lens mount that drives the focus motor between the lens and the camera, but I'm not 100% certain on that. Your camera can focus lenses with and without this type of coupling. BUT, if that screw/motor in the body is not functioning, you'll only be able to use lenses which contain the focus motor inside them, or manual focus lenses (you can manually focus AF lenses too).
I have a weird problem. When i put the 50mm 1.8 on my D90 it continues to autofocus even when I switch the camera body to M mode instead of AF with the switch. I would like to be able to manually focus...
You probably have a problem with the A/M switch on the body-- flipping that switch should extend or contract the autofocus pin that drives the lens. This particular lens doesn't have its own focus motor, so there's no way that it could be focusing on its own without the pin from the body driving it.
Try taking the lens off of the camera and looking at the autofocus pin as you flip the switch from auto to manual focus.
1helpful
2answers
I bought a Nikon D90 a few weeks ago. It worked
Your camera may be faulty. Or you might not be "in focus". The D90 in any of the auto modes won't take a picture if the 'in-focus indicator' isn't on. If that indicator is blinking, then it means that it is not able to focus on the subject. It's all in the user manual.
AF 50mm D - no autofocus with the D90
Your motor may have gone bad. Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
9helpful
2answers
D90 Nikon autofocus problems
Try a reset (hold down both buttons with green dots next to them) and see if that helps.
Also try cleaning the contacts on the lens itself (light rub with a pencil eraser usually works well).
Lense will not work with SLR Nikon D90
This lens is too old for the D90, it has not got the electronics for metering and autofocus.
You can use it manually in M mode but you will have to set the aperture and shutter yourself.
The D90 manual has a section on compatible lenses, page 228 in my version.
This recommends CPU lenses for the D90, type G and D.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
