Appreciate the direct "Ask Me".
I am assuming that by your post "...
the player worked fine..." refers to the unit operating as expected. To your concern:
- clock resets;
- dvd player light flashes on and off;
- missing ding driver's door open.
All of the above indicates a wiring error or at the very least a loose connection more particularly to the mains B+ (
always on). The always on B+12 is directly tied to the + battery terminal and as the name implies, with or without the key in the IGN SW, there is a +12. This always on B+12 is responsible for the clock to maintain its time, the memory of the headunit to retain presets tuner stations and all other settings. It is also responsible for providing the power to the "ding" circuitry and sensor. Pls re-check that the following wires are connected as indicated:
- Yellow (with the filter/fuse) - always on B+12
- Red - ACC +12 (ignition switch)
- Black - car body ground/negative
- Pink - Handbrake switch
- Green/White (if present) - reverse switch on the gearbox
- Brown (if present) - mobile phone in use mute trigger (if used)
- Blue - to power a motorized/amplified antenna (if needed)
- Blue/White - to power an external amplifier (if used)
Additionally, if I may inquire, year, make and model of the car it was installed in.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
My Jamo systems is doing the same thing, the blue light flashes on and off but the system doesnt respond to the remote or the buttons at the front. We have returned it to the shop and after 6 weeks we have received a replacement. We have this system a week now and it has another problem. From time to time it doesn't respond to the front buttons.
Jamo 5.1 DMR61
