Question about Powerware 9120 UPS System
Replacement fans for powerware 9120
I need to source 2 x replacement fans for Powerware 9120 ups
    Problem Solver:
  • 4 Answers
9120 fans are rare and uncommon, for alternate solution just replaced the bearing of the fan.
Posted on May 27, 2010
    Scholar:
  • 39 Answers
A good electronics supplier should have. Get the correct voltage and size, and get one with the largest CFM available.
Posted on Apr 13, 2010
SOURCE:
Can I replace the fan in a live powerware 9120?
hey dude your problem is so simple..below are my solutions.
if you already secured the fans for the replacement then its easy for you to do it, try to totally shut down your UPS removing the input and battery supply. avoid replacing the fans with power, its to dangerous. it consist of almost 400VDC inside in it.
call me if you want +63923 3024 585
Jul 11, 2013 | Powerware 9120 UPS System
Powerware 9120 6000i model indicates a charger failure. It is the first time that we opened this unit and we do not know the location of the charger circuit (we do not have a schematic diag). Could you...
The charger in powerware 9 series 9120 6000i ,the fan is of a quality that it fails and the heat sink does not get sufficient cooling ,it runs on 12 volt ,i replaced it with a cpu fan from a mainboard on a pc and it works perfectly now. make sure that the fan is running else the charger might go in protection or can fail due to the transistor on heat sink fails.
Feb 08, 2011 | Powerware 9120 UPS System
I need qty:10 from ups poweware9120
The Powerware 9120 UPS has been replaced by the Eaton 9130 (www.eaton.com/powerquality). You may be able to get some 9120 models from www.powersupersite.com. Just do a search for 9120.
May 18, 2010 | Powerware 9120 UPS System
I have a Powerware 9120 2000 UPS battery failure message
After you replaced the batteries did you perform a manual battery test?
If not do so.
Regards
Alan Hood
ami-man
UK
Mar 03, 2009 | Powerware 9120 UPS System
Fan is running constantly
in the 9120 series the fan is allways working, but as 2 speeds. the higher goes of when the load goes around 80% or the temperature inside is higher. just make sure the the fans are clean, and check the ups temperature.
but is normal.
good luck
Jun 09, 2008 | Powerware 9120 UPS System
Powerware 9120. 1500i UPS
You can download the manual and other literature at
http://www.powerware.com/EMEA/UPS/9120_info.asp
The contacts for support in India are found at
http://www.powerware.com/India/Service_Support/IN_Office_Contact.asp
They offer a battery monitoring software package, at
http://www.powerware.com/India/Service_Support/IN_Battery_Services.asp
You can email support at http://www.powerware.com/pp/Check.asp?key=code1
Good luck
Feb 20, 2008 | Powerware 9120 UPS System
Powerware 9120 UPS System Logo
826 people viewed this question
Top Powerware Computers & Internet Experts
Marvin
Marvin
geekyshrink
geekyshrink
Level 1 Expert
B.Th. Pluijm
B.Th. Pluijm
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
