The Pull cord was jamming. I took it apart and found it was wrapped around the motor and caught in the screws that holds the coil in place. Now I'm not sure if the cord is suppose to go around the motor or not and it won't retract back into the coil. Are there any instructions in regards to the how the cord should be in the mechanism or how to fix this type of issue. It's a Homelife Might Lite 26ss
The rope and spring both have thier respective place in the housing for thier mountings they can be rewound by hand and reassembled with success,hint oppisite end of spring has a anchor point on the housing while one end is secured by a cup like screw mounting,to create the retracting force for retrival of the pull start rope its tricky if haven't done it before but you learn by trying Good luck Steve
