My motorola i9 phone has no battery life and im trying to charge it on a usb pluged into the computer because wall charger is broken and it wont charge there is a blue light that comes on by the outlet on the phone but dats it and the phone will try and come on but go right back off
try charging on a wall charger? im assuming you have a usb wall connector to match your computer charger like i do, also try it on different options besides mass storage.
What you are describing is that there is an issue with the USB charging port on your V3i. Different pins are used when charging via the wall as opposed to via a USB computer port. It really is quite common with the V3i, you can search on the internet to get your port repaired. If you cannot find anyone, feel free to ontact me, outlet3g in the repair directory.
It won't turn on because battery is too low. Another benefit of lithium ion batteries. When they are depleted, the internal controller / charge circuitry on battery disables it.
You didn't mention what kind of phone other than Motorola. If it has a USB connector to charge through, make sure that you are using a motorola approved charger. There is a way to make the USB connectors (charger side) indicate a particular class and rating. If this doesn't match what the phone expects, then you will likely get a Cannot Charge message or similar.
That being said, this usually only happens with AC wall chargers. I have yet to see it happen with a vehicle charger, though I don't rule it out.
I have the same Problem me and my sister both bought one about 2 months ago and now they wont charge :( such a waste of money and both batteries wont charge. Because they are from hong kong i dont know what to do ??
I think the charger is the problem. I ordered one of these and then it wasn't charging the day I got it....it's supposed to go from red, to orange to green as it charges, but the red LED just goes off after a while, before the headset is fully charged. I solved this by charging it through a USB-to-miniUSB cable on my laptop USB port. This worked beautifully....unfortunately I think the H700 chargers are faulty.
Your charger is faulty. If your phone is able to charge off of other sources (computer, car charger, another wall charger) Then, the charger needs to be replaced. Some mobile companies have a 90 warranty on accessories like the charger and battery. Then the mobile manufacture (Motorola) has a 1 year warranty on the charge and battery. I would check on that, and get those replaced.
the issue is with the wall usb ac adapter just replace it (with a better quality one) and it should work, you can also charge the phone using your computer. Well... this fix worked for me.
I don't know if this applies to the Sansa for sure or not but many MP3 devices and smartphones if completely dischard will not charge back up via usb to computer, you have to use a wall jack charger. This is true for the Motorola Q and other smart phones I know for a fact, also the Apple Ipod Gen 5 has had some issues with charging after complete discharge of the battery. Try a wall charger if possible. I don't know much about the sansas.
has it worked before, if not, try pluging the usb into the back of the pc, as there is more power coming from those usb hubs. if that doesnt work, i suggest spending the $20 on a wall charger.
