Plugged in my wii, put in game on disc channel, pressed start, and then the screen stays dark and the machine is quiet. After almost a minute, the game starts up. I called Nintendo customer support, and even the help desk never heard of this problem. It loads fine afterwards, but then again, this happens randomly...help?!
I don't know how to help you here. You can either have patience for the games to load or send it in to Nintendo for repair if you still have your warranty.
Important Note! Do Not use "One-Time Mode" sync. Syncing can be completed only if a compatible game disc is running in the console.The Wii Balance Board may need to be synced to each compatible game individually.Some games may require you to go into a specific screen to sync the Wii Balance Board.These sync settings will be saved even after the console is turned off. 1. Insert a Wii Balance Board compatible game disc in the Wii console.2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game.3. Open the SD Card slot cover on the front of the Wii console.4. Remove the Battery Cover on the bottom of the Wii Balance Board. 5. Press and release the SYNC button on the Wii Balance Board. The Power LED on the board will start blinking. 6. Press and release the SYNC button on the console while the Power LED on the board is still blinking.7. The Power LED will stop blinking and light steadily once the synchronization is complete.8. Replace the battery cover and return the board to the normal operating position.
1.Insert a Wii Balance Board compatible game
2.Use the Wii Remote to select the Disc Channel
from the Wii Menu, then select "Start" to begin the game. Press the A
Button to bypass the wrist strap screen.
3.Open the small SD Card slot cover on the
4.Remove the Battery Cover on the bottom of the
Wii Balance Board.
5.Press and release the SYNC button on the Wii
Balance Board. The blue light on the board will start blinking.
6.Press and release the red SYNC button on the
Wii console while the blue light on the board is still blinking.
7.The blue light will stop blinking and stay on
steady once the synchronization is complete
Wii Balance Board.
steady once the syncronization is complete
Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
Open the small SD Card slot cover on the front of the Wii console.
Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
The blue light will stop blinking and stay on steady once the syncronization is complete
The blue light will stop blinking and stay on steady once the syncronization is complete.
Use
wrist strap screen.
The blue light will stop blinking and stay on steady once the synchronization is complete.
please leave a good rating and testimonial if you appreciate my help. THNX
If Wii gives Disc Read Error, first step you need to check is to try
another disc or clean the exisitng disc. This will confirm that problem
is with either Wii or Disc. If the console itself is giving disc read
error then it needs to be repaired. You may check out DIY Wii Fix Guide,
that will show step by step information to fix the problem yourself. It
also gives information on fixing many Wii Related Problems, so its a
kind of Wii Problems Reference Fix Guide
I think thats normal. If your really annoyed about it, Play some music that cancels out the noise. I'm sure the in-game music your playing should go over the buzzing noise.
