Dmm Nuance Dragon Naturally Speaking 10 Preferred Wireless Full Version for PC  Logo
Posted on Sep 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cannot save my user files in Dragon Naturally
For the past 2 months, I cannot save my user files in Dragon Naturally Speaking 10.1. I have tried repairing the install and I completely uninstalled and then reinstalled the program but the error persists.
Error Details: The file exists.
Anonymous
Level 3:
President:
  • Master 1,187 Answers
  • Posted on Sep 30, 2009
Anonymous
Master
Level 3:
President:
Answers
1187
Questions
0
Helped
528374
Points
4102
Instead of "Save" files, use the "Save As" option.
Dragon Naturally Speaking Playback is not working with Word document.
This link would better explain your issue and has the best solution.
Ihope that will fix the issue...
Dragon Naturally Speaking Playback is not working in Word document
1helpful
2answers
DRAGON NATURALLY SPEAKING, WHEN i CLICK ON ICON I GET ERROR "ACTXPRXY.DLL DID NOT REGISTER ITSELF" CAN I DOWNLOAD THE FILE ?
Hi Leonard May 11, 2014 Joel RodriguezAdd a CommentAfter doing some research on this dll error I found that it associated with a ActiveX conflict with corrupt or missing system files. May 11, 2014 Joel RodriguezThings that you can try: put your windows disk and run the system file checker in command prompt (here is a youtube link on how to run it http://youtu.be/rNDBRYdDXqo ) fast forward video to 4:40 and follow. This will check the integrity of your systems files . Second you will do if that didnt work you would re-install the Dragon Naturally speaking software and drivers of any device that you are using with the dragon software. here is the hardware compatibility list from thier website http://support.nuance.com/compatibility/ . If still a no go . May 11, 2014 Joel Rodriguezinstall the dragon software to another computer if you dont get that error then its your windows then. Doing a clean reinstall of windows and updating new updates. then you will install dragon software.
May 11, 2014
Lookup serial number
The key might be on the manual or the box if its not on the cd.
Dragon Naturally Speaking is a software program designed by Nuance Communications that enables a user to speak instead of type to both transcribe information and control his computer. This is beneficial if you don't like typing or physically cannot do it.
The software requires a headset microphone to work and some configuration to get started. To continue using Dragon Naturally Speaking, you must register it or it disables itself.
Activation is done online and requires a product serial number.
The location of the serial number varies depending on the software version, but it should be located on the box, CD case or manual.
Start Dragon Naturally Speaking.
When it completes the loading process, click "Activate Now" when prompted and then click "Activate Automatically."
Enter the serial number in the space provided and click "Generate Activation Key."
Copy the activation key into the activation text box and click "OK" to activate Dragon Naturally Speaking.
How to activate Dragon NaturallySpeaking without an Internet connection
http://www.spectronicsinoz.com/article/how-to-activate-dragon-naturallyspeaking-without-an-internet-connection
MY DRAGON NATURALLY SPEAKING 10-PROFESSIONAL DOES NOT WORK IN AOL EMAIL. IT WORKS WITH EVERY OTHER PROGRAM. BUT, WHEN I TRY TO DICTATE IN AOL EMAIL, NOTHING HAPPENS. ANYONE KNOW OF A SOLUTION?
Dragon Naturally Speaking 10 has not been tested to work with web based e-mail. It's also the same thing with Dragon Naturally Speaking 11 regardless of any version. As a work around and fix for this, if you want to use it through on any web based e-mail is to use the Dictation box.
Here are the simple steps to access the Dictation box:
1.Make sure you have successfully loaded a working user profile. 2.On the dragon bar, go to tools and then go to "Dictation Box" 3.Here, you can start dictating e-mail messages and use the "Transfer" button to transfer text in AOL E-mail.
I hope this solves your current problem.
I can't access Nuance Dragon naturallyspeaking 10 Speech to text
If you have a non trial version of it, I'd try uninstalling and re-installing the program. Many programs will save personal configurations when you uninstall the program, so it is possible that you wouldn't need to make it learn your voice again. I've never used this particular software though so I can't offer any personal experience on it.
The speech recognition that is built into Widnows 7 is great though. I've used it and think it works very well. You can go through a tutorial and read to it for it to learn your voice.
Cannot uninstall dragon 10
I CANNOT UNINSTALL DRAGON 10 FROM MY COMPUTER TO INSTALL TO ANOTHER
[email protected]
Top Dmm Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Dmm Computer and Internet Expert? Answer questions, earn points and help others
