Samsung HL-R6167W 61" HDTV Logo
Posted on Dec 19, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Help i had the color wheel replaced and now the picture is not center up and down the top i can see a line going across how do i fix
Anonymous
Level 3:
Genius:
  • Master 1,030 Answers
  • Posted on Dec 19, 2007
Anonymous
Master
Level 3:
Genius:
Answers
1030
Questions
Helped
227552
Points
2244
Who replaced it. to replace a color wheel most of the time you have to remove the light engine. sounds like they did get thing tighten down and lined up. take it back and tell them to line it up
LN46B610A5FXZA Gray Horizontal across full Screen with color vertical lines in lt corner and center of screen
Sounds like a panel defect. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
My 32inch tv turns on but the picture is wired.
On a 32 inch it may not be worth fixing--not going to be a reset etc--base decision on fact that possible repair should not exceed used value of set--which in my view it likely will.
I have a Mitsubishi WD-62525. In general the picture is great from all sources (cable, component, and hdmi). However, there occasionally are very thin, horizontal lines that flicker across the screen....
I have seen this problem before. It is usually caused by a malfunctioning color wheel. Replacing it should resolve the problem. Let me know if you wish to fix it yourself so that I can find you a replacement.
2answers
Picture freezes
a freezing picture is normaly due to bad input signal have your imp input signal checked
Samsung DLP R&R Color wheel Model #HLR5078w
Samsung's digital light projection (DLP) televisions use a spinning color wheel to create the colors that are seen on the screen. If the color wheel becomes misaligned during use, it will become damaged and have to be replaced. Replacing the color wheel on a Samsung DLP television can be done at home, once a compatible-sized color wheel has been bought from a TV supply store.Replacing the color wheel yourself will void any Samsung warranty that might be in place, but is the only solution for getting the TV working again in as short a time as possible.
Put on the anti-static grounding strap to keep static electricity from damaging the internal components of the Samsung DLP TV. Turn the Samsung around so that the back is facing you. Make sure the Samsung is unplugged from the AC socket.
Use the Phillips screwdriver to remove all of the screws from the back panel. Put the screws aside. Pull off the back panel.
Loosen the two screws from each side of the projection bulb's case. Pull the projection bulb out. Put the projection bulb aside. Use the Phillips screwdriver to remove the two screws from the left side panel. Pull the side panel and the circuit board attached to it out carefully and put it down so that the cables attached to it have not been pulled out.
Take a picture of the power cable's position with the digital camera so that you can put it back correctly later. Pull the power cable out from inside of the Samsung's case so that the center panel is free to be pulled out. Remove the two large headed screws from the center panel with the Phillips screwdriver. Remove the top two screws holding the panel to the plastic case using the Phillips screwdriver.
5
Slowly slide the center unit out a few inches. Take a picture of the projector lens' positioning with the digital camera so that you can put it back correctly later. Unplug the two cables from the left side of the center panel. Unscrew the sensor switch using the Phillips screwdriver. Slide the center panel completely out of the Samsung and put it down on the clean cloth. Blow off the color wheel assembly with the compressed air.
6
Use the tweezers to remove the green plug from the top of the color wheel cover. Use the tweezers to remove the two cables at the side that are coming from the color wheel. Use the Phillips jeweler's screwdriver to remove the screws from the top, front and back of the color wheel cover. Slide the color wheel cover straight up to expose the color wheel.
7
Use the Phillips screwdriver to remove the three screws holding the color wheel to the color wheel assembly. Lift the color wheel up and out of the color wheel assembly and discard it.
8
Position the replacement color wheel in the color wheel assembly. Reassemble the color wheel and reassemble the color wheel assembly. Put the color wheel assembly back into position in the rear of the Samsung DLP TV. Reassemble the Samsung DLP TV. Plug the Samsung DLP TV back in for power. Turn the Samsung on and enjoy seeing the colors displayed properly again now that you have replaced the color wheel.
My Samsung 56 DLP picture lost is color and is making a buzzing noise which I suspect is the color wheel. The picture is now black
you need to change the color wheel
5
6
7
8
2helpful
2answers
Color wheel for Samsung HLR5688WX DLP TV
5
6
7
8
Samsung TV Model HL-R5067W
go here they are adjusting speed of the color wheel
2answers
Color line across the center of a black screen
Hi. this is caused by dry solder joints on the frame o/p IC. Resolder all legs of frame chip. Should sort that out.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
