My daughter has only had her ds for one day when after charging it she could not get in to any of the games in the N-Card. It just says file write error. Thanks
The proper solution is here: http://wiki.answers.com/Q/How_can_you_download_games_into_the_n-card_for_nintendo_ds_lite
To be short:
- Connect the DS to a PC via USB
- Select USB mode
- Via MS Explorer, select the card and delete all the savegames on the card (.SAV)
- go into your DSYSTEM directory and delete the LASTSAVE.sdb and restart the Ncard
Thats it. Cause is probably a bad saveby one of the installed games. I've had the issue with FIFA 2007.
Its cos u put a corrupt game on.Once played it wont let u play any others till u take off.Will b the game wi 2 v 's on end of sav file.......
If you having trouble with files try reformatting your ds console it worked for me
Since it's brand-new I suggest bringing it back to the store for help. Someone in the video game section should be able to diagnose (in person) whether it needs to be repaired or replaced.
i have a ds fire card and i deleted some games off it n put some more on i was playing on it then i turned it off then turned it bak on later n said file write error on all the games n wont let me play them?
I was downloading games on my ds and one day i went to play it it came up file write error. i have tried everything i can think of.
I create the game and I click when I finished the project of create file...
And this says me the CMD file:
C:\DSGameMaker\Temp>make clean
Der Befehl "make" ist entweder falsch geschrieben oder
konnte nicht gefunden werden.
C:\DSGameMaker\Temp>pause
Drücken Sie eine beliebige Taste . . .
Sorry...
I have german Windows XP
If says, he can´t make the file
make clean error
make error
thanks
