You should have 2 components with your micro SD card. The card, a small adaptor and a large adaptor. All you need to do is see what size adaptor your read needs. You place the card in the tiny slot in the adaptor and slide it in the reader. The computer will find the micro SD and install the driver to read it. Then it will give you an option to open the files. That is how 99% of them work.
This will need to be inserted in a Micro SD card adapter. You can use one made by Kingston, San Disk, Lexar etc...
The adapter is standard size.
if theres a slot for an sd card on your computer you need a micro sd card adapter. if it doesnt have an sd card slot you need to buy a usb memory card reader (making sure it takes a micro sd card first)
both are widely available in supermarkets/electrical outlets or on ebay/amazon/play etc and are very inexpensive.
(micro sd adapter)
(memory card reader)
