Mitel Superset 4025 Corded Phone (mitsup4025) Logo
Posted on Sep 30, 2009
Changing the name on the mitel superset 4025 I have replaced someone at work and I am trying to change her name and add mine. So mine shows up on the caller id when I call someone within the company. How do you do this. Please help. If you are able to call back my number is 773-565-6054 thank you soooo much Ms. Blackburn
Anonymous
Level 1:
  • Contributor 37 Answers
  • Posted on Dec 24, 2009
Anonymous
Contributor
Level 1:
Answers
37
Questions
0
Helped
36469
Points
46
Ms. Blackburn, You will need access to the phone system to accomplish this task; the change needs to be done in the “Telephone Directory form” typically this is done by the system administrator.
How do I change the date and time on a Mitel Superset 4025 phone system?
The time has to be changed in the programming interface of the phone system itself. You cannot change the time from any set other than a 4150 or a super console 1000. These sets can only be used to change the time on a mitel sx200 or icp. This does not work on the 3300.
My phone at the school that I work at is a Mitel Superset 4025, with the daylight savings time/time change. My phone for example reads: 11:20am when it is right now 12:20pm. Could you please guide me...
Your Mitel telephone gets it's time from the system, not from within the phone. The system admin or vendor will need to log into the system to make the time adjustment.
Most school districts that I have dealt with have an IT staff that has the ability to log into the phone system to make changes to things like names, extension numbers, reset mailboxes, and time change to list a few.
I am sorry that I really can't help resolve this without redirect to them.
Sincerely,
Mark
How do I change the time on the Mitel Superset 4025
You will need to contact your Vendor to have them change it. The time is for the entire phone system, not just an individual telephone.
Most sites I work with, have a site admin that can set the time. If they can't someone should contact the supporting vendor.
Good Luck,
Mark
How do I change the time on the Mitel superset 4025
Either your on-Site system administrator, or your vendor will have to make the change. This is a system wide setting, not just your phone.
2helpful
2answers
Mitel Superset 4025
Phonebook is for internal extensions. As soon as you add a ext. and name in phone system it is added to the phonebook.
How do I set the time on an mitel 4150 and 4025 phone
Need to log into phone system or if the 4150 is a sub att. you go through the softkeys.
Phonebook on Mitel Superset 4025
It depends on your Mitel Telephone system.
If your system is an SX200 ICP ~ then going thru the Blue Superkey options the Mitel will let you change your own name.
But ~ if you have a 3300 ICP then the name change is only performed via the system programming.
Want to divert calls from a Mitel Superset 4025.
Under the Blue Superkey, you can find a Call Forward prompt, enter the extension that you want to transfer your calls to and enable it.
To shut the call forwarding off, go back into the Blue Superkey and in Call Forwarding,t here is a disable call fording option
9helpful
Changing time on my Mitel Superset 4025
The only way to change the time on your individual phone is to change the time on the entire phone system.
Top Mitel Lands Phones Experts
k24674
Are you a Mitel Lands Phone Expert? Answer questions, earn points and help others
