Computers & Internet Logo
Posted on Dec 19, 2007
PrintMaster Platinum 7.0
Will only print one copy. Have select anywhere from 2 to 10 copies and will only print one copy. Also have tried different printers with the same result - one copy. Running XP.
Thanks
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 15, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
782
Points
I LOST CD 3 HOW DO I REPLACE IT ?
I have Printmaster Platinum 17 on my computer. It has stopped coming up and will not reload. Is there a site where I can download it again? Maybe directly from the internet?
Lest's star by telling you neither me nor FIXYA had ever released any version of Printmaster Platinum 17. OK? So, if you want to contact authors of this sofware, ENCORE SOFTWARE
Encore Official Site Download Top Software Hoyle Card Games The Print Shop...
Now, HAVING SAID THIS, dd you use ever Printmaster Platinum 17 with Windows 7? I understand that it is for Windows XP.
I'm no sure what kind of a mess you made with it uninstalling or removing but well, try to reinstall your original SETUP version in Windows XP COMPATIBLITY MODE
Befor you instal it cricght click setuo, select Properties, click on tab Comatibility and select option Windows XP Comatibility mode
If won'r work, I find no way to help you,
LOOKING for the old yellow trifold Printmaster Platinum Program, Art and Photos CDs. It has an address-birthday anniversary list that I can't find in the later versions'. I bought two, one is...
Based on your question, I am assuming you are looking to purchase this from anywhere you can find it. Amazon.com has it:
http://www.amazon.com/Mindscape-112947-Printmaster-Premier-7-0/dp/B00003IE80
If purchasing another copy was not your intent, reply to this answer and let me know what you need. I hope this helps you!
4helpful
Will Printmaster Platinum 16 run on windows 7 I
Printmaster Platinum 16 is not compatible with Vista or windows 7.
I installed window 7 into my laptop. My printmaster platinum 18 is now not working properly. What can I do to resolve this issue
Right click on the program shortcut click on properties from the menu and click on the compatibility tab , check "Run this program in compatibility mode of windows xx" and select the version of windows in which the program used to run. Apply the settings and open the program again. If the program still doesnt work try to reinstall or get an updated version for windows 7 maybe Print Master 2010.
2answers
Can i install the print master platinum 16 on my new computer with windows 7
ypu cannot use print master platinum 16 with windows 7 or for that matter vista
I have an old copy of Printmaster that originally was on my Windows 95 machine then I got a Windows XP machine and could use the same projects. Now I have a laptop running Windows 7 and had to buy a new...
Hello
Thank you for using FixYa for your problem
have you tried the import mode
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
2answers
Doesn't seem to support windows 7
no version of printmaster supports Windows 7 yet
2helpful
Is it possible to install / import old PrintMaster 7.0 Art Discs?
When you put the Program install disk in follow the prompt but instead of selecting the "Typical" instalation select "Custom". This way the install will instruct you to select the two or one or none Art cd.s. I assume your copy of Printmast 17 Platinum has all 4 cd's?.If not then you will only have installed about clip 950 art etc. instead of 19,000 plus when you install the Art disk 1&2.
The only drawback is that the two art disc's add another 1gb to the hard drive usage.
I hope this helps.
Brian Wright
Printer printing more then what is needed
while uninstalling the epson driver it will ask you for delete the setting or do you want to keep it. if you select keep it, it will happen how many times you install the driver. Check the printer settings in printers and faxes window, select printer go to printing preferences, page layout and check whether you give no. of copies to 2 there.
Top Broderbund Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
