Can't seem to find a way of taking off the glass lenses. Stoves oven model 059850512.
When you look at the glass lamp covers (lenses), you will see a little raised section either at the front or back of the lense, depending how the lense was replaced previously. You need to put the largest screwdriver blade you can under the lip and turn it slightly. The cover should move and then ease the screwdriver round the lense until the lense comes clear.
Note. Cooking gunge may may this action difficult as it will cause the lense to stick and also when you replace the lense, you will see on the inside of it there is a moulding cut away to clear the bulb. Make sure when the lense is replaced, the recess is positioned so that it clears the bulb. Whilst you have the lenses out, use the Lakeland brush on oven cleaner to give them a good clean. The end result makes a difference!
