Televison & Video Logo
Anonymous Posted on Feb 02, 2018
Virgin v+ box
Hi i have a virgin v+ box (basically a sky+ box)
the gemini G510S works with it but only does some functions it wont let me go 2 home page all it seems 2 do is change channels, volume ,pause play stuff like that is there a way to get the gemini to do all the functions please help thanks.
1 Related Answer
Anonymous
  • 273 Answers
  • Posted on May 30, 2009
SOURCE: where is gemini located in the night sky
this link should help
http://www.astro.wisc.edu/~dolan/constellations/
1helpful
WHAT SKY BOX CAN I USE WITH A KV-28LS35U SONY IN SPAIN
Your TV has a SCART socket. So you can use anything from a plain "receive only" Sky box through to the recording HD boxes. As long as the box also has a SCART socket then the TV and box can be connected.
If you take a box abroad with you to leave there permanently then you'll need to think about what kind of contract (if any) you want. A Sky box without a viewing card will let you watch a broadly similar range of channels to Freeview in the UK. There's a useful comparison guide here: http://www.ukfree.tv/allchannels.php
Used Sky boxes are available cheap from Gum and the Facebook selling pages, or have a look in your local classifieds.
If you buy a recorder box, remember that the recording and Live Pause features are only available with a Sky subscription. They don't work with an expired viewing card or no viewing card at all. If you think you'd like to record programmes while abroad then consider a Freesat PVR instead. It will cost more in the short term, but you will have the same kind of functions as a Sky recorder box.
One other option is TV via the net. There's a device called Slingbox. It uses the internet to port your home's Sky box signal to you somewhere else in the world. You don't bother with a second Sky box, just add a Slingbox digitiser to the home Sky box and connect it to your internet service. In Spain, you have a Slingbox receiver connected to the internet and your TV. What you've then got is control of the UK Sky box, and those signals sent to you in Spain via a web connection. You operate the Sky box in the same way you would at home. The difference is that the TV is 1500 miles away.
Slingbox relies on you having a decent internet service in Spain. That might not be practical, or possible, or even desirable. But if you want to have your full Sky package in a second location without forking out for a whole year's subscription then it is one solution that wiorks.
tip
Watch your SKY channels on a second TV with Magic Eye and remote
If you have Sky Multi-room this will feed a separate SKY signal from your LNB on your dish to a second SKY box if you have the basic this will not cost you anything you still need a card inserted in the front to make this work. I think it costs £5 extra for more channels.
So if you have SKY + you will have 3 coaxial cables coming out of your LNB. ( 2 for the SKY + and 1 for the Multiroom )
To ger the signal for free the easy way is to connect a coaxial cable from the RF2 output on the back of the SKY ot SKY+ box into another TV and use a SKY Magic Eye these cost about £5 and have a range of about 20 meters. You can use a coaxial splitter to feed two TV but you will loose more signal the more you connect.
You will need to turn this function on using the hidden menu to allow you to use the Sky Remote control then LED on the unit will show you that there is a signal.
Press <SERVICES> <4> <0> <1> <SELECT> and goto the RF2 output to turn the signal on you might find that this signal is already turned ON for you.
Note: If you are using a multiplex faceplate unit this signal will not work as it relies on continuity of the coaxial cable with a 12V DC signal being sent out of the back of the SKY Box.
For all setups changing you Box model or adding an extra box SKY must to this for you by having your phone line connected so they can reprogram your Smart Card.
Virgin tvvo box
Not sure about about the transmitter but the magic eye thing is possible however you wouldn't be able to change channel unless your pointing your remote at your box because a sky box has power going through the magic eye but a virgin box doesn't
1helpful
How do i connect my blue ray Samsung ht-bt1220 2.1 to play through my sky hd box
Connect an optical lead from the sky hd box to the Samsung Blue Ray.
Then change the function button on the Blue Ray to Din 1.
Then change settings on Sky HD box to Dolby and this worked.
4helpful
2answers
Star view 5 start up (Virgin Media)
Press menu on handset.Standing on installation press numbers 1570. Changes to nagravision. Press OK. This will get you to key providers. Scroll right till you get to telewest/virgin.Use handset to put codes in 00 first then 01.Press store after each set of codes.
Telewest/virgin codes updated 12/10/09
00 - CF 53 OC 33 79 61 71 85
01- 52 5E 8D 45 FC 75 F6 4A After this press exit to the start.
You might have to do installation.
Press menu. On installation press 1668.While on telewest press OK. It should input all channels.
4helpful
2answers
Manual. need to know what the connections are for
User guide or Manual for Amstrad Sky+ ...YYY
2 posts - 2 authors - Last post: 27 Jun 2007
I need to add a second sat lead from the LNB to the Box. None the less I need a book of words that tells me about the Amstrad 180 sky+ box. ...
forums.vnunet.com/message.jspa?message... - 29k - Cached - Similar pages -
Sky Digibox remote control codes for your television
This User Manual is the ideal solution if you've bought a Sky Digibox without one. .... it ALSO operated ALL of the functions on my Amstrad Sky+ receiver (not .... in the Digital Installation Manual or via the Sky Customer Service option in ... This actually selects Sky+ mode, but a Sky+ remote works a sky HD box. ...
www.satcure.co.uk/tech/digicode.htm - 49k - Cached - Similar pages -
User manual AMSTRAD SKY PLUS - User guide AMSTRAD SKY PLUS ...
User guide AMSTRAD SKY PLUS. USING YOUR SKY+ WELCOME TO YOUR SKY+ BOX GUIDE .... to repair your Sky+ box. For repairs, please contact Sky Customer Service. ...
safemanuals.com/user-guide-instruction... - 98k - Cached - Similar pages -
For Sale : Amstrad Sky+ Box and QED 1.5m Squart Cable - AVForums.com
Due to an upgrade to Sky HD I have for sale my old Amstrad Sky+ box (model no. DRX180). ... Will try to find the manual for it as well. ...
www.avforums.com/forums/home-cinema-hi... - 102k - Cached - Similar pages -
Amstrad Sky+ Box - HELP PLEASE! - Sky+ - Digital Spy Forums
6 posts - 5 authors
Amstrad Sky+ Box - HELP PLEASE! Sky+. ... The Specifications in the manual state: Hard Drive: 160 Gb (with 80 Gb for personal use); the packaging also has ...
www.digitalspy.co.uk/forums/showthread... - 55k - Cached - Similar pages -
amstrad sky plus on standby
Following the instructions at the top of page 66 in the Manual fixed it. .... Go back and wait by your sky+ box and you should see the red recording light come on, ... Sky & DLM, Sky Broadband Service Status, SkyUser Bandwidth Meter ...
www.skyuser.co.uk/forum/sky/17069-amst... - 117k - Cached - Similar pages -
sky+ box keeps making beeping noise. - Cable Forum
15 posts - 3 authors
can anyone tell me how to stop sky+ box from making a beeping noise, ... thanks paul ill read manual & see if that helps. my sky+ is an amstrad pvr3. ...
www.cableforum.co.uk/board/64/33616556... - 87k - Cached - Similar pages -
Sky+ box amstrad dx280 - FixYa
Technical Support, Instructions & Repair Service. Home | My Expertise | Sign In ... Related Searches: sky remote, sky box, amstrad, skybox, sky manual ...
www.fixya.com/support/t1223689-sky_box... - 49k - Cached - Similar pages -
MobilePhoneMadness.com - GUIDE: Upgrading Your Sky+ Box
Amstrad Sky+: Equal in size as the Pace Sky+ V2 and looks identical, ... We hope Sky will fix the V1 firmware at a later date, as there no manual fix we can ...
www.mobilephonemadness.com/forums/arch... - 13k - Cached - Similar pages -
Amstrad DRX 180 - Review - How did we live without it???
The problem with the cable service, however, is that when you look at the ... No matter which Sky+ box you end up with, the instruction manual is the same ...
www.ciao.co.uk/Amstrad_DRX_180__Review... - 82k
2helpful
No instructions for a goodmans remote
there are a few numbers for a goodmans tv (the codes are for gemini 6 in one)they all enter 3 digits
002 004 009 027 028 051 068 093 111 115 127 153 169 171
hope that helps
1helpful
2answers
Surround sound to work with sky+
hi yes it is....
wot u need to do is.....our red and white audio leads go from sky box to dvd box...we then put our dvd player onto video 1 using function button on remote
hope this helps
Panasonic TV Instruction Manual
Is there anything mentioned about cable accessible via the remote ... assuming you have one that works for the unit?
2answers
Top Gemini Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Gemini Televison and Video Expert? Answer questions, earn points and help others
