Question about HP PhotoSmart 7350 InkJet Printer
My HP 7350 PhotoSmart has been printing excellent photos; however, when I enchance my photos with MS Office Picture Manager, I do not get the same result from my printer as what the monitor is showing.
  • 630 Answers
Two different systems that is why, each one has different resolutions than the other.
Let me know how this worked for you and please do not forget to rate my service so we are able to improve on it. The rating as follows 1 the service was not related to the post. 2 the service was related but not did not help at all. 3 the service was to the point and somewhat complete. 4 the service was excellent and to the point.
Posted on Sep 29, 2009
SOURCE:
Why does the photo tray not engage in hp 7350
Look for jammed paper of some other object that might have fallen into the machine.....
Aug 07, 2014 | HP PhotoSmart 7350 InkJet Printer
How do you get your hp 7350 to print iron ons without lines in the photos?
Hello, here are a couple things to check.
1) Make sure your ink levels are good. Are you using original HP ink? Do not use refills.
2) Use a higher resolution when you go to print. (Click on Preferences to change the resolution. Look for Print Quality and select a minimum of 1200 DPI.)
Hope this helps.
Thanks for using Fixya.
Dec 09, 2009 | HP PhotoSmart 7350 InkJet Printer
The kodak gloss paper gets jammed in my hp photosmart 7350 printer towards the end of printing photos
You have an HP printer. I highly recommend you use HP photo paper for the best results. This may not solve your jamming problem but it may. HP printers are very touchy as to what photo paper you use.
Nov 24, 2009 | HP PhotoSmart 7350 InkJet Printer
Two sided printing
You have to get a dulexer. It ataches to the back of the printer.
Oct 23, 2009 | HP PhotoSmart 7350 InkJet Printer
My HP 7350 Prints Almost Nothing
You should try going into the properties and running the head cleaning that will fix ya right up
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Aug 27, 2009 | HP PhotoSmart 7350 InkJet Printer
Getting wet blurry pictures from the hp 7350 printer, what is wrong?
go int the printer utility and run the "clean print head" or nozzles, they are all a bit different
Dec 20, 2008 | HP PhotoSmart 7350 InkJet Printer
Printing is printing blank sheet of paper
Lots of reasons here but usually it is because the software you are using to print is not compatible with the operating system anymore. Example: you used MS Photo Editor which was discontinued in 2003 and never supported under Windows XP. The one function that is broken is printing...it looks like it printed but a blank sheet of paper comes out. (exactly what you described)
Instead, use MS Picture and Fax Viewer or the follow-on product, MS Office Picture Manager.
If you remove the MS Photo Editor application under Control Panel/Software Programs then your picture files will open with a different (more print compatible and friendly) program.
Jun 21, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP PhotoSmart 7350 InkJet Printer Logo
64 people viewed this question
Clive
Clive
Thomas F. Schneider
