Posted on Sep 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Forgot passcode to ipod
I forgot my passcode to my ipod touch. Now its disable and says connect to itunes and I did and that did not help. So how can i get my passcode?
Anonymous
Level 2:
  • Expert 68 Answers
  • Posted on Oct 15, 2009
Anonymous
Expert
Level 2:
Answers
68
Questions
0
Helped
13910
Points
143
You'll need to restore the software with iTunes. Select the iPod in iTunes, under the Summary Tab, select Restore. You will then need to resync it as well.
Forgot my ipod pascode lock
If you own an iPod touch, you have the option to set a password, which Apple calls a passcode, to protect your data. Anyone who attempts to access your iPod, after unlocking it or turning it on, will require the passcode to do so. However, if you forget your passcode or incorrectly enter it, you will eventually see an alert that your iPod touch has become disabled. To unlock your iPod touch after forgetting the passcode, and still access your content, you must connect it to the computer with which you last synced it.
Connect your iPod touch to the computer with which you last synced the music player. Launch iTunes if it does not automatically open. Select your iPod touch under the devices list, and click the "Summary" tab in iTunes. Click "Restore" and, when prompted, click the "Back Up" button to save a back up of your iPod touch in iTunes. Click "Restore" when prompted, after the back up saves. After restoring, click "Ok." Choose the most recent back up from the drop down list on the "Set Up Your iPod" screen. Click the "Continue" button to restore your iPod touch.
iOS: Forgotten passcode or device disabled after entering wrong passcode
http://support.apple.com/kb/ht1212 iTunes: Restoring iOS software http://support.apple.com/kb/HT1414
Ipod touch model a1288 is disable forgot passcode and wont let me connect to itunes messages says enter passcode to connect
The most logical option would be...
- Connect your device to iTunes (The same computer it is set to sync with)
- Hold the power and home buttons
- After the device shuts down, release the power button
- Your device should then be in recovery mode, at which point you may release the home button upon seeing a message on iTunes that basically says it has detected an iPod in recovery mode.
Forgot passcode for apple touch ipod
If you forgot your passcode then you need to restore your iPod touch. To do this:Connect device to your computer that you sync everything within iTunes go to the device and on the front there should be restore your iPodClicking on this will allow you to access your iPod touchNOTE: you MAY lose your data by doing this.You have been warned.
I forgot the passcode to my iTouch
k ppli just got ma itouch but got it used and it wont let me do anything it only says ipod is disable connect to i tunes and i did wene i go to i tunes it says itunes could not connect to ipod because it is locked with a passcode you must enter your passcode on the ipod before it can be used with itunes so wat could do plz help
1helpful
Forgot passcode, ipod disabled. i dont no what to do
  1. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPod touch to turn off.
  2. Press and hold the Home button while reconnecting the USB cable to iPod. When you reconnect the USB to iPod, the device should then power on.
  3. Continue holding the Home button while iPod starts up. While starting up, you will see the Apple logo.
  4. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
  5. Restore and it'll download ~240mb firmware and you're done
Warning: you will lose all your data
15helpful
3answers
Ipod touch 16gb, passcode forgotten screen reads disabled.
well you can conpleatly restore it by no luging it in and holding the power buton for 3 seconds then with out leting go of the power buton hold the home buton for 10 seconds then let go of the power buton and just hold the home buton for a further 30 seconds.....
after you have done this plug it in to your computer with iTunes allready running and a icon should say unresponcive ipod or somethin along those lines just click RESTORE
hope this helps
dale gough
41helpful
5answers
Ipod touch disabled
Try turning off your ipod, holding the home button, and plugging it in, while still holding the home button, until a picture of the ipod cable appears pointing to the itunes symbol. this will reset you ipod, and you don't need the passcode to make it usable again.
 Grubhead
Grubhead
SmartAviator
SmartAviator
