Question about Jura Capresso Impressa E75 Espresso & Coffee Maker
How do I disassemble and clean the brew unit motor on my Jura Capresso E8? The machine will brew coffee but it goes through about three cycles to get the grounds to eject and be ready to brew again. I have cleaned, decalcified, wiped out, brushed, etc., and I still have the problem. I don't want to pay $250 for a refurbished replacement.
    New Friend:
  • 13 Answers
I have some good instructions I downloaded from www.kaffeestudio.com . They are in German, but with many pics. If you are technically adept, then it is really no prblem. You should put in new o'rings and lubricate with the food grade silicon grease before reassembly, otherwise it won't be long before you are doing it again. Give yourself about 3 hours to perform this task the first time. One thing to remember. The cleaning tablets tend to strip the lubrication from the brew units, subsequently binding up the brew unit, sometimes tearing the o'rings and giving the malfunction 8. Plan on this being an ongoing maintenance exercise. Plan on at least once every year or two to have to do this.
Posted on Oct 18, 2009
    New Friend:
  • 21 Answers
Here is a direct link to download the repair instructions:
http://www.juraprofi.de/Service-Anleitungen:_:70.html
Posted on Jan 12, 2013
SOURCE:
It has error 8 on it what do u think?
Jura Capresso Impressa E8 Espresso/Coffee Maker Error 8 ...
www.fixya.com > ... > Jura Capresso Impressa E8 Espresso/Coffee Maker
Jura Capresso Impressa E8 Espresso/Coffee Maker, error 8 related issues. Get free ... We have just done a full disassembly, cleaning, and relube of our Jura Z5 ...
Bosch Benvenuto B30 Espresso/Coffee Maker Error 8 ...
www.fixya.com > ... > Bosch Benvenuto B30 Espresso/Coffee Maker
Jan 14, 2016 | Coffee Makers & Espresso Machines
Turning dial after choosing strong, we want 4 oz, but turning dial toward 4 it may goe to 5 and then up to 7 down to 6, up to 8, etc.
Operating Manuals - Jura Capresso Coffee Machines
capresso.125west.com/html/operating_manuals.html
Operating Manual Impressa F9 and F9 Limited Edition. Operating Manual Impressa F7. Operating Manual Impressa E8. Capresso C1300 Superautomatic ...
Sep 06, 2015 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura Capresso E8 keeps getting error code 8 over and over. I will clean, remove grounds etc, it will make a few espressos, then back to the error code. I can hear it struggling.
One of the problems that I see with these units is the Grinder setting. Sometimes the grinder is set too fine for Dark and Oily beans. This setting will ( can) clog up the brew screen after less than 10 cups are brewed. Also, running the cleaning tablets through to create a clean starting point may help you. Try turning the grinder to a slightly coarser setting and try that.
Sep 21, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
Cleaning instructions for jura E8
I am not sure if you are referring to the standard clean that the E8 requests. If that is the case the instruction are to press the rinse button for 5 seconds, until it asks you to remove the tray, then follow the instruction on the screen (they are normally, rinse, rinse, add tablet (should be Jura one) - add to powder shoot, then the process runs through.
If you are talking about de-scale then you should us the Jura de-scale tablets, but vinegar and biccarb can also do the trick.
Feb 05, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
Error Code 8 ?
The brew unit can`t move to the right position. This means usually that is full of used grounds and needs to be cleaned. Use your finger and clean out everything stuck inside, and then run the cleaning program. If this doesn`t help, contact your servicecenter, then it may be that the brew unit needs to changed or revised.
Aug 14, 2009 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura impressa f9 malfunction 8 i need help whats that
Malfunction 8 means that the brew unit can not get in the right position in the right time. This is usually because the brew unit is full of old coffee grounds. Try to shut down the machine for one day. The next day, take out the tray and clear out all coffeegrounds inside the brewunit. Use your fingers and maybe a small towel. You can do this right away, but it is easier when everything`s dried up. When all this is cleaned up, start manually a Cleaning program. This should solve your problem.
If it doesen`t, i could be that the o-rings inside the brew unit is defective and needs to be changed.
Jul 08, 2009 | Jura Capresso Impressa E8 Espresso/Coffee...
My F9 displays Malfunction 8
Malfunction 8 is related to the brew unit typically. It is usually an indication of the brew unit motor having to work too hard to move the brew unit up and down. This is usually cured by disassembling, cleaning, replacing any o'rings that may be bad, and lubricating the unit, then reassembly.
I have had to do this twice on an an E75 and an E8. I finally broke down and bought seal kits and food grade lubricant for doing this. (I have only been able to buy parts from Europe online) One could by a new brew unit off of e-bay and change out the whole thing. But a simple cleaning or rebuild will typically suffice. One note. The cleaning tablets tend to strip the lubricant from the inside of the brew unit over time. Ocassionaly the seals in the brew unit will fall apart and bind up the unit. Either of these is usually accompanied by a sound of the brew unit motor straining to cycle the machine. If you are not savy in repairing it you may want to send it in. I suspect they will tell you it needs a new brew unit aand quote about $300 USD for the repair. About two hours, much patience, and about $10 in parts is most likely all it may need.
Mike
Jul 04, 2009 | Jura Capresso Impressa F9 Espresso Machine
Rinse error
I'm not exactly sure what was going on as I tried again to push the rinse button possibly a little harder this time and now it is working fine.
Sep 26, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura impressa E75.message mafunction 8 shows up
I have had to do this twice on an an E75 and an E8. I finally broke down and bought seal kits and lubricant for doing this. One could by a new brew unit off of e-bay and change out the whole thing. But a simple rebuild will typically suffice.
Mike
Aug 12, 2008 | Jura Capresso Impressa E75 Espresso &...
E8 leak
If leaking water from right front when brewing, cleaning or steam then the possible problem is the feed tube from the pressure pump this is mounted with a small o-ring and either the pipe is fractured or the o-ring has perished.
Feb 05, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura Capresso Impressa E75 Espresso & Coffee Maker Logo
1,786 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
