My tv have 3 vertical black lines side right
I want to know the possible cause of tv with 2 black line at the top and bottom of the screen. Is it have the same causes even if the tv model is not the same..thanks
Your lucky day folks! it worked for me perfectly! read carefully and follow closely!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
enjoy!
stephen
I'm sorry you have not been given a clear ansewer on how to repair your TV. I know how to fix the problem you are having (1.5 inch Black vertical lines that come and go) If you still need help fixing your Plasma TV please feel free to message me @ [email protected] or just give me a call @ 1-503-432-9904 and I'll help you fix your TV buddy! Ask for Dave!
Talk to you later buddy!
Dave
Two black lines straight down my tv
SOURCE: 42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
SOURCE: Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
SOURCE: red vertical line down right side of the screen
hi
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use robber
Place the rubber on the top of TCP
Gently close back the top casing
Good luck...
I have a large verticle black line down the middle of the screen.
started with one black line that would come and go and now have 3 black lines that are all vertical from each other
two black line straight down the tv
I have the same problem except I can barely see the picture and at first it went away after it warmed up?
