Having problem with yellow not printing. Have done normal maint. cleaning and pulled print head and soaked in alcohol for several days. Get very little yellow out of printer,Having problem with yellow not printing. Have done normal maint. cleaning and pulled print head and soaked in alcohol for several days. Get very little yellow out of printer,
AnonymousOct 20, 2008
I replaced print head with new oem part I still can not get yellow I replaced print head with new oem part I still can not get yellow
Same type of thing - only after several Deep Cleanings, I can get a light green band where yellow should be. Cyan seems ok, but Magenta is more lavender than anything. It's to the point now there's no better returns on subsequent deep cleanings.
thanks.Same type of thing - only after several Deep Cleanings, I can get a light green band where yellow should be. Cyan seems ok, but Magenta is more lavender than anything. It's to the point now there's no better returns on subsequent deep cleanings.
thanks.
AnonymousMar 31, 2014
cyan ink out. but want to print black and whitecyan ink out. but want to print black and white
You can't post conmments that contain an email address.
I just placed all new cartridges into my Canon i560 printer. The photo I printed came out all orange and black. Plus there were stripes (1/8") acrosse the picture.
If any of the ink cartridges need to be replaced the printer will not work. Also, if you are printing only black you will need to go into print properties and select black.
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks. This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
On this machine you have to install inks with power on and use the ink button and choose replace ink. If you just plug them in it won't register and reset the counts. You may need to run clean cycles at least twice to get proper colors.
Try remove all cartridges then put back it one by one.Make sure the color cartridges are not empty too.The printer need all cartridges not empty to initialized and working.
You don't have to replace the coloured cartridges if you only use black. But if you print something that is not pure black then it will use the other colors. For expample, if you print on a gray scale, since this is a color printer it will use the colored cartridges to get the gray color. The colored printer will only use the black ink for pure black colours. If you just use black to print, why not use an inkjet printer that just prints black or uses black cartridge. It is available in the market.
I find the best way to clean the heads is buy some cleaning cartridges as they have cleaning fluid in them and use them to clean it will take about 10 or more times to clean the heads then put the color ones back in and try again.
Just keep putting it on clean the head don't do a print out till at lest you have cleaned 10 or more times.
Yellow won't print even though just installed new cartridge.
thanks.
