Does your "lamp" is turned on when you open the cover? If not it could be that you have bad lamp controller pcb.
Try to manually pull the lamp on right side, and then turn on the copier, if lamp assy is moved in left position withaut error, that means that position sensor is OK, and you need to focuse yourself on "lamp"/ LED
