Great TV with years of flawless service. Picture is not quite lined up from top to bottom, is out of "kilter" about 1 inch each way (in other words top needs to come down and inch or so or bottom needs to go up about the same,
That's in your vertical cirsuit and most likely caps that are failing.. You might notice that it gets a bit better or worse after it's been on awhile. Clearly worth the service to have a tech ESR test the caps in the vertical circuit and replace any that are questionable. Always replace C2p05 100 mfd 16 V on this set, in fact most all 100mf caps are usually found stressed.
Good Luck!
Bill
