JVC AV-32D305 32" TV Logo
Posted on Sep 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a jvc tv and connot program ch 3 on tv to hookup my direct tv reciver tv says its in lock mode need code to onlock help if u can thanks brian
  • Anonymous Oct 31, 2011
    cannot program ch 3 on tv tv is in lock mode
Rod
Level 2:
Champion:
  • Expert 224 Answers
  • Posted on Sep 29, 2009
Rod
Expert
Level 2:
Champion:
Answers
224
Questions
0
Helped
46248
Points
493
I have Direct TV. I need to program, my remote to it. I need the code for model # SK-32H650G?
https://support.directv.com/app/answers/detail/a_id/4028/~/how-to-program-directv-remote-control
full directions:
1. tv
2. press and hold MUTE & SELECT for two blinks
3. enter 9 9 1, wait two blinks
4. enter 1
5. press and release VOL UP
6. point the remote at the tv and keep pressing and releasing the CH UP key, if and when the volume changes
7. press select to lock in code
Need the code to program my universal remote to my jvc tv the serial# to my remote is rc24922-c1122 model jc024
Do a code search method as follows.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
I would like to program an older Samsung tv to my JVC LP21036-038 Remote I need the codes?
Unfortunately, the JVC LP21036-038 remote can only control JVC devices. It doesn't have any adjustable codes. You can choose between 3 codes (A, B, and C) so that using 3 JVC video devices doesn't result in conflicts. This remote came with the JVC HR-XVC14BU among other devices. The manual for the VCR/DVD player is available from JVC support. The direct link to the manual is http://resources.jvc.com/Resources/00/00/90/LPT1148-001A.pdf . See page 17 of the manual for the details.
I'd recommend you get a cheap universal remote to control the Samsung TV and the JVC vcr/dvd player.
I wish that I had better news for you.
10helpful
3answers
Hi, I have the ESPN college gameday remote and I lost the manual. Could someone please give me the code for a sylvania tv? Thank you.
Manually turn of the device the user wish to power scan (TV,PVR,DVD,VCR etc.
For more than 3 seconds press and hold the appropriate device key. The LED comes On, indicating that the remote is in programming mode.
Press and release the Power key. The LED blinks once and stays on, indication that the Remote is in power scan state.
Press CH up or CH down key repeatedly untill the device switches ON.
When the devise turn ON, press and release the SELECT key to program the remote with the new code and exit.
I have a polaroid HDtv and can't program my Brookstone remote to it. can you help? The tv model number is TLA-01911C
There is no code for polaroid tv's for that remote so you will have to do a PowerScan through all the codes to see which one will work. The procedure to do this is below.
Step 1: Manually turn off the device you wish to program (TV, VCR, DVD)
Step 2: Press and hold the appropriate device key (TV, VCR, DVD) until the red LED illuminates. This indicates that the remote is in programming mode.
Step 3: Press and release the power button. The LED flashes once and stays ON. Indicating that the remote is in PowerScan mode.
Step 4: Press either CH+ or CH- button repeatedly until the device switches on. The CH+ button searches upward in the code list while the CH- button searches downward.
Step 5: When the device turns on, press and release the OK button to store the new code and exit.
NOTE: If you press the CH+ or CH- again after the device turns on, the device will not be programmed and you will need to repeat steps 1 - 5.
Step 6: Press any other operable button (VOL+ or VOL-). If the device responds, no further programming is required. If the device does not respond then repeat steps 1 - 5.
If you try scanning through all the codes and none of them work then the remote is not campatible with your tv.
8helpful
How to sync with tv
Hi, i could tell you what code you need to program the remote if tell me what brand tv you have. If not you can try PowerScan through all the codes to see which one will work. Procedure is described below.
27helpful
Code for jvc tv with ge universal remote
Here are the GE Universal Remote 4 digit codes for a JVC TV.
0060... 0026... 0197... 0069... 0160...0247... 0923... 0012... 0065... 0067... 0141
Direct Code Entry
1. Press and hold the SETUP
2. Press and release the
VCR, etc.). The red
stays lit.
3. Enter the 4 digit code from
the code tables. Note:
after a valid code entry,
the red indicator turns off.
For an invalid code, the
red indicator flashes.
4.With your device on,
press CHANNEL UP. If
required. Note: If some
buttons do not operate
your device, try one of the
other codes for your
brand.
Note, when all codes have
been searched the red
indicator flashes rapidly for 3 seconds.
Hope this helps!
Sincerely, CBR2009
12helpful
Need remote code for Bresnan Cable 5-1 remote for Sharp 32" LCD
Apparently I didn't read the directions for code search closely enough (as it does work for my tv). So I will post them here, just to be sure people don't make the same mistake I did.
With the Device on;
1) Press "TV" on the remote control
2) Press and Hold the "Setup" button until the light blinks twice
3) Enter "9" "9" "1" to enter code search mode on the remote
4) Press the the "CH+" slowly until your TV turns off (if you accidently go to far your can press "CH-" to go back a code or two)
5) Press the "Setup" key to lock in the code, the light should blink twice if done correctly
Your device is now programmed, enjoy!
Programming Code
Barring the right codes to make this thing work, I have resorted to running the numbers (ie 000 thru 999) to "stumble" across the right combination...accordianman
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
