Samsung YP-U2X Digital Media Player Logo
Posted on Sep 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My i-pod shows error
My i-pod (YP-U2J) shows error when it load the files, because some files are deleted by mistake, so i want help. Provide me that files please
Anonymous
Level 2:
  • Expert 30 Answers
  • Posted on Sep 28, 2009
Anonymous
Expert
Level 2:
Answers
30
Questions
0
Helped
13486
Points
106
Some of the files you deleted are probably the files that contain the installation settings, if thats the case you'll have to restore back to factory settings or download new settings online.
How can I delete songs from my Samsung yp-u2j?
Deleting Files,Pictures,etc from MP3 Player
Hook up your mp3 player to your computer Go to your desktop and double left click on "My Computer" When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there. Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible. Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete" Now you mp3 player should be clear of the files/songs you do not want. Be careful and do not delete files needed to operate your MP3 player. Good Luck, I hope this helps Please rate me, Thank You
How do I delete songs on my samsung mp3 yp-u2j?
what you do is you right cick on the song you want to delete and it will say delet then cick on that
4answers
I/o error YP-U2 mp3 player
looks like the usb interface's worn out.. it might be due to a fall or **** happened to the player.. get it checked at your nearest service center..
4helpful
YP-U2J - Need download - Didn't come with CD
In case you have a problem to connect your Samsung YP-U2J Mp3 player, you should update Firmware to get it working. The new Firmware may be downloaded from Samsung.com.
CLICK Here to Download : Firmware Update
In case u have WMP 11 and player not working, this error is common after installing Windows Media Player 11
Here is the instruction:
  1. Download the YP-U2J Updater
  2. Remove Mp3 player if you already connected to the USB port
  3. Run the program (You should see something like: Please connect the device)
  4. Hold down the Play button and connect the Mp3 Player to USB port (Hold down the play button while you connect the device, you should see a message (normally after 8 seconds) like: Initializing on YP-U2J Updater program screen)
  5. After you hear the Windows chime "new device found" or the message "Initializing" on YP-U2J Updater, you can now remove your hand from play button.
  6. Check the Format Data Area checkbox (By clicking the yes button, you will lose all of your data in your Mp3 player)
  7. Click the "yes" button
  8. Finally, click on the Start button (takes less than a minute). DO NOT REMOVE YOUR DEVICE
  9. IMPORTANT: After updating the firmware, you MUST disconnect the Mp3 player and turn it on. You will see a 20% message for about 50 seconds and it will be restarted automatically.
Update: Please keep in mind that if you sync your Mp3 player with a computer that has a Windows Media Player 9 or 10, you should do these steps again
Cannot use my player-device manager problem/deleting files
This error is common after with Windows Media Player 11
2answers
Deleting
I have the same problem! Please post if you figure out how to delete such files!
2answers
Yp-u2j
My samsung yp-u2j is not connecting, its realy pissing me off, because my cumputed wont download the new hardware i need...
1helpful
YP-U2JXB & YP-U2JZW Won't sync...Help!
Error C00D1236 virtually always indicates one of two things:
1) The device is trying to sync hidden files--are there any?
2) There is licensed media that is being synced, and the license is either corrupt or has expired. If you have any licensed media, then try going back to where you purchased it (in an iTunes-like music management program? In WMP?) and refresh/renew the license.
The bad news is that until C00D1236 is resolved, you can't sync your device. frown.gif
You can bypass syncing, and directly transfer files, In my computer, the mp3 plaer will be shown as a drive.
Now if one of the two solutions above is not feasible for u, try this:
This error is common with Windows Media Player
1helpful
2answers
Mp3
If the operating system was deleted, then you need to buy a new MP3 player.
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
