Symbol Motorola MC3090 Handheld Computer Logo
Posted on Sep 28, 2009
Data loss while scanning a 2d label. it is not capturing entire contents
Andrew Kowalski
Level 1:
New Friend:
  • Contributor 65 Answers
  • Posted on Jan 25, 2010
Andrew Kowalski
Contributor
Level 1:
New Friend:
Answers
65
Questions
0
Helped
46941
Points
77
If you are using data wedge to scan then it needs to be configured. I can provide steps necessary for this request. You can always contact me directly [email protected] or 630-622-2024 toll free 866-271-9891 Ask for Andrew
How do I take a screenshot om my macbook
Capture the entire screen
  1. Click in the onscreen controls. Your pointer changes to a camera .
  2. Click any screen to capture that screen, or click Capture in the onscreen controls.
  3. Use the thumbnail to markup, share, save, or take other actions.
Capture a window
  2. Click a window to capture that window.
    To exclude the window's shadow from the screenshot, press and hold the Option (?) key while you click.
Capture a selected portion of the screen
  2. Drag to select an area of the screen to capture. To move the entire selection, drag from within the selection.
  3. Click Capture in the onscreen controls.
  4. Use the thumbnail to markup, share, save, or take other actions.
Capture a menu
  1. Click the menu to reveal its contents.
  2. Press Shift-Command-5 while the menu is shown.
  3. Capture the menu by following the steps to capture the entire screen, capture a window (the menu is treated like a window), or capture a selected portion of the screen.
Where do i buy ARGOX GE-200 PLUS
Argox launched Ethernet industrial label printer
Adopted Ethernet management makes industrial printer strengthened
Argox adopted Ethernet into industrial printer series and launched X-2300E(203dpi) for regular resolution printing and X-3200E(300dpi) for high-resolution printing to meet different demands. Both X-2300E and X-3200E are equipped with enlarged memory - 8MB Flash Memory/16MB DRAM- leading ahead of competitors. The built-in RTC(real-time clock) is also an advantage to work alone with the printer to print time/date on the label without a PC.
X-2300E/X-3200E provides PPLA/PPLB/PPLZ(X-2300ZE, X-3200ZE) emulations for all application. And the auto calibration function supports 4 modes of setup provides flexibility for the users to choose the most convenient mode for different printing applications to ensure accurate label detection.
To satisfy the requirements of industrial printer application like wide area between operation systems in network and large number of equipment, utilizing Ethernet to deliver printing tasks is a more economical choice for enterprises. X-2300E/X-3200E installed Ethernet server to provide the interface of Ethernet data transfer and by using SNMP setup to deliver the error massage back to managing server to simplify the procedure and enhance efficiency.
X-2300E/X-3200E supports Windows 7 system and 1D barcode, 2D barcode, QRcode and etc. It's suitable for the production line of manufacture including safety labels, patent labels, and?parts-name stickers, and fit for the application of shelf-label printing management, storage, delivery, shipping, transportation, luggage labels and wash care labels for clothing.
LINK IS GIVEN BELOW..................
http://www.argox.com/content.php?sno=0000486
GOOD LUCK......................
2answers
How to Scan 2D barcode on MC55 (mc5574). How to enable Imager mode to scan 2d , as currently my mobile (mc55) only scans 1d barcodes. Thanks
unfortunatley if your device is preconfigured for 1d only you will not beable to scan or decode 2d barcodes. Which configuration of the mc55 do you currently have? if you can provide me with this information i can let you know if it is possible or not.
1helpful
Hi all i am trying to use barcode scanner in Motorola MC55 Handheld Mobile Computer. i have installed data wedge from...
Hello, Datamatrix is 2D Symbology. Actually this MC55 is a model with 1D Laser Scan engine. The laser cant scan 2D barcodes, therefore he is not decoding the datamatrix barcode.
You would need an MC55 with an 2D Imager or with Camera to scan 2D Barcodes.
105SL is taking template from Label Matrix and stretches it so the data matrix part is unreadable when scanned. How do I make it take an existing template and retain the print size, font and 2D?
Check to make sure you have a 105SL printer driver. Also check to see if you have chosen ZPL for the language as well as the proper resolution (203, 300 and 600 dpi).
2answers
MC3090 is having trouble scanning 2D labels. It
No...check the printer that is creating the 2D code. It's probably the culprit. Make sure the head is perfect and the 2D code is big enough. The 2D version of the MC3090 doesn't read small 2D codes.
If it still doesn't work, contact your dealer or the Moto Help Desk at 1-800-653-5350
2answers
How to remove virus from Acer D150-1165
Scan the entire laptop and then it should detect it and let you remove it
1helpful
2answers
Unwanted underscores added to 2D barcode scan
are they the same barcode type?
what is the font set at? using Arial or other fonts can make the software send a more complicated image. use the Zebra Triuverate font. this keeps it simple. also, do a print out of the settings on each printer and compare them line by line. change the settings to match the printer that is printing correctly.
Datalogic QS6500BT barcode scanner and 2D codes
Usually some symbologies are disabled at default.
i think you need the manual and scan the barcode to enable it for scanning.
the links is:
https://easeofaccess.scanning.datalogic.com/public/marketlit/Send.aspx?file=R44-2816A
it's chapter 6-191 or page 279 in pdf.
you have to begin with scanning "Start" en end with scanning "END"
becarefull with printing this page and not the whole manual. there are 336 pages.
good luck
Top Symbol Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
