using 3rd party toners??? if so replace them all and use OEM also re-seat the image units, and the transfer belt and transfer roller Worse case have a tech come out have the firmware re-flashed firmware is not drivers comes from secure Konica Minolta web site available to only dealerships and KMBS to protect there copier/printer firmware..
Hi I am former Konica Tech Support for 26 years. I do some network problem. Y may need to upgrade the copier memory. or this just simple setting. on the printing side I can assure you no problem. there is a setting on the operation panel choosing if you prepared pdf when ever you to e-mail, scan to box or scan to SMB. You can delete the old print driver and the control panel delete your even the printer Icon at the printer and fax folder. Re install the printer and the printer driver. And make sure send a test print. If so happened that you don't have the print driver you can go to Konica web site and download the print driver. There are many kind of print driver. postscript driver and etc. I hope this info will help you and if not you may contact me again.
Kyocera Mita Ai 3010 works well only with OEM toner. Print System has no decent drivers for XP and forget about Vista. Doc feeder needs separation rollers every 15,000 feeds. I will replaced it if needs more than $250 in parts.
I had the same problem one time, they told me to pull out all of the toner cartriges, power off, power on, power off, replace all cartridges and the problem went away.
