Question about NorStar Lands Phones
Fixing home tel. new line
I am living in Alvesta,I need to have through ur Mega Phone a telephone line in my home,one of my friends who is using ur co. advise me to contact u,his name is Anwar Qasqas.per.nr.7401185173,and his home tel.nr.0424955440,
my address
Samir Ahmed AlNatour
ANGAGARDVAGEN 8 A
342 31 ALVESTA
    Top Expert:
  • NorStar Master
  • 29,653 Answers
Why not direct your request to the supplier. We are not a supplier.
Posted on Dec 15, 2017
SOURCE:
sandrew
  • 2961 Answers
SOURCE: Noisy phone line with 2wire rpoter
if the line is clear, just use a line filter only where you have a phone fitted and nowhere else, that way you can try the different filters if you are using more than you need as it sounds as if one may be faulty. Also check any extension leads you may have or remove and check you phone line again for noise. If there is noise it would normally stop you from connecting to the internet also.
Posted on Jul 01, 2007
smileysue74
  • 11 Answers
SOURCE: I deleted a contact from
It will probably stay until a different contact takes it's place. You can also try adding their name again exactly as it was. After that, edit from your list of contacts by changing the contact name and number to that of directory assistance or other contact.
Posted on Dec 23, 2008
  • 5 Answers
SOURCE: Can Siemens optiPoint 500 phone be used at home
An "Optipoint 500" phone can not be used at home!
It is a digital phone, specifically designed for Siemens digital phone systems. Do not plug it in at home. That could damage the phone or may knock your phone line off.
However you can use a "Optipoint 500 IP" phone at home for voice over IP calls. But this would be connected into your broadband router and would connect via the web to your companys Siemens phone system.
Posted on Aug 04, 2009
  • 45 Answers
SOURCE: How do I change the display name on incoming line
You would have to go into program mode.
program 93-1 would do the trick.
Tony
Ameritel
732.477.7733
Posted on Oct 05, 2009
  • 489 Answers
SOURCE: hi i got a message
I don't know who or what o2 Telecoms is ... but this sounds like a scam / fraud to me. You should never send your email address and password to anyone !! unless you want someone else to access your email and do whatever they want with it ... pretending to be you.
I suggest you change your password right away ... and do not click on any link that they provide !
Posted on Feb 27, 2011
Panasonic PNLC1017, our landline telephones do not work. I've changed batteries, the phone screen reads check tel line. Please help!
The PNLC1017 is the charger for the handset of some Panasonic cordless phones. One of the compatible handsets is the KX-TGA660 which works with the KX-TG4112 system.
However, the 'Check tel line' message indicates a problem at the base or the POTS (Plain Old Telephone Service) telephone line. The system is not hearing the dial tone. Check that the power adapter is plugged in to a live outlet and is warm. If it's cold, than the power transformer is not working and the base has no power. If there is power, check if the handset message disappears when the handset is close to the base. This is usually rare but indicates a transmitter/receiver in the handset or base is not communicating properly. You can try to de-register all handsets and then register them again.
To check the phone line, I prefer to use an older corded phone. These don't require power to work. First, try a new phone data cord (RJ-11) between the base and the wall jack. (I've seen someone accidentally use a handset cord which doesn't work.) Test if there is a dial tone when this cord is plugged into the test phone. If there is a dial tone, then if the cordless phone base didn't work with the replacement cord, the base is faulty. Replace it or contact Panasonic if the system is under warranty. If you have a DSL fliter, this may be damaged. If it's inside, replace it. If it is in the service box, ask your telephone provider to check it.
If there is no dial tone, you need to locate the other phone jacks for that phone line. Find where your phone service comes in as well. Check if there is a dial tone on another jack for that phone line. If there is no dial tone, check the service box for an RJ-11 jack, Test for a dial tone there if you can plug in the RJ-11 cable. If you have a dial tone at another jack, then the problem is local to the first jack's wiring. You can open the jack and check for loose wires. There are two styles of jacks - screws or punch-down. For the screw terminal, strip the insulation and wrap it under the appropriate screw. For the punch-down keystone jack, you need a punch-down tool. The tool is available from most home improvement/building supply stores, in the wiring section. Do not strip the wire. Use the tool to press the wire down into the correct slot on the jack. See https://www.lanshack.com/wire_phone_jack.aspx for the wiring diagram.
If you can't test the phone line or there is no dial tone at the service box, then you need to contact your telephone provider. It used to be that the provider would always test and fix outside problems for free. Some telephone companies are trying to stop repairing copper wiring. If you have a dial tone at the service box, then the problem is somewhere in the inside wiring. You may want to get someone to find a broken wire in the wall for you. Your telephone company service technicians will do this for a fee.
I hope this helps. I've had the check tel line issue times several times at my home. Twice, the outside line was damaged by mice and repaired by my telephone company. Once, a lightning strike damaged the DSL filter; it was promptly replaced. Other times, the line was damaged by contractors digging too close to the underground utilities. The contractors got the wiring repaired. When our service was switched to a fiber-optic system, we lost one telephone jack when the installer simply didn't plug in the wire. We found the loose wire behind the siding and plugged it into the port in the service box ourselves. Since then, we lost telephone and other service intermittently when the modem card in the service box was failing. That was also replaced by the telephone company technician.
Sep 01, 2018 | Panasonic Lands Phones
Cannon mx 330 printer/fax. I plugged into the comcast modem for Tel 1 line then to the back of the cannon fax L. that didn't work so I connected it to the telephone line on the back of the fax..Help
The Pixma MX330 Line port needs to be connected to a POTS (plain old telephone service) line jack with an RJ-11 cable. A standard corded telephone or the base of a cordless system gets connected to the Tel port on the MX330. The Comcast modem connects devices to the internet. You might be able to use a VOIP (voice over internet protocol) service between the MX330 and the modem. You will need the appropriate hardware (MagicJack, Ooma) in between the modem and the Pixma and get an assigned telephone phone number.
Generally, you will need a compatible router to share the cable modem's internet service between any computers and a stand-alone VOIP system like the Ooma.
I hope this helps. Please add a comment with more about your Comcast hardware for additional information. I know my home's fiber-optic modem service does support POTS, in addition to the internet and TV service. Each service has their own wiring/jacks that go back to the modem.
Jun 28, 2018 | Cannon Office Equipment & Supplies
"Check Tel Line": Do I need a new phone?
theres some thing wrong with the base unit, try unplugging it and plugging the whole setup at a friends or something, also if youhave a DSL line you my have to install a filter to seperate the data line and voice line. Its ole school but this might work.
Feb 16, 2014 | Uniden DECT 6.0 Cordless Telephone...
Error message CHECK TEL LINE my phone line is connected and i followed all the right steps to connect my handset to the base HELP!
This sort of issue requires you to check if the base or the phone line has a problem.
I prefer to use an old corded phone for testing. I also get a new RJ-11 cable. Unplug your phone base from the jack and check for dial tone when you plug in your test phone.
If you get a dial tone on the test phone, try the new cable with your cordless phone. If you still get that message, then the phone has failed. If it is under warranty, contact the manufacturer for repairs. If it is out of warranty, then determine if it is worth fixing or replacing. These phones are not designed to be fixed by the end user.
If you do not have a dial tone, take your test phone to another jack on the phone line. Check if there is a dial tone at that point. If there is a dial tone, the problem is at the first jack or the phone line to the jack.
If you still do not have a dial tone at the second jack, find where your telephone service comes in. Open the box and determine the type of connection used. If you are lucky, it will have RJ-11 connections. Plug your test phone into the jack and check for a dial tone. If you do not have a dial tone at this point, call your telephone company. They will fix the problem for free. If you find that the connection is not an RJ-11 type, call the phone company and have them test the line and repair it if needed.
If you have a dial tone at the service box, then you have an inside wiring problem. Inspect the visible wires for damage. Open the faceplates for the jacks and check for loose wires. There are two types of connectors. Screw type connectors need the wire stripped back a little then wrap around the screw and tighten. The other type is a punchdown jack. To repair a loose wire in this, you will need a punchdown tool. These are often available in hardware/home improvement stores in the wiring section. http://www.lanshack.com/wire_phone_jack.aspx has clear pictures of the wire color to pin pattern.
You may want a professional to check the wires inside the walls. Your telephone provider will do this for a fee.
I hope this helps.
(who has had outside phone line problems due to rodents chewing on wires, road crews digging just a little too much, and lightning damaging a DSL filter.)
Jul 07, 2011 | Uniden Cordless Phone
Panasonic KX-T7433
These phones are digital proprietary telephones which means that they only work on panasonic telephone systems and not on normal analog lines. If you have a panasonic system the correct way is to plug the line into the " To Main Unit ", the handset into " Handset/Headset" and a normal analog phone into " To Tel ". If the wiring on the line jack was not done digitally the phone will also not work
Feb 16, 2010 | Panasonic KX-T7736 Corded Phone (KXT7736)
What is wrong when the phone says Check tel line?
The telephone cord may not be connected correctly.
  1. Unplug both ends of the cord connecting the wall jack to the telephone base.
  2. Insert one end of the cord to the TEL LINE jack on the base.
  3. Make sure that the cord is inserted correctly in the TEL LINE jack on the phone.
  4. When you insert the cord you should hear a click.
  5. Insert the other end of the cord to the wall jack.
  6. Make sure cord is inserted correctly.
  7. You should hear a click.
Feb 02, 2010 | Uniden DECT 6.0 Cordless Phone ID
Office NEC phone to be used at Home
This phone is a proprietory digital phone that only works with a KSU. You would need an IPK or Elite phone system to make it work. You would also need to program it. This is a business office system and that phone will not work unless it is plugged into the system.
Feb 05, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
How to connect canon L295
Hi THe main difference in the phone fax line is that if you are only using as a fax plug the cable from phone socket into the line socket sometimes this may be marked line/tel then the hand held phone goes into the tel socket.this should make it a little clearer..line to wall socket ....and tel to hand telephone
May 02, 2008 | Canon L295 Plain Paper Laser Fax
Can I use this fax on a telephone line together with a GE 2.4 GHz Cordless Telephone (Model 27992B)? Will it be possible to recive messages and faxes when no one is at home? Remark: The answering machine...
sure u can: Installation with an answering machine and/or extension telephone: 1. Remove the seal covering the TEL. SET jack on the rear of the fax. Connect an extension telephone or answering machine to the TEL. SET jack. 2. If desired, connect an extension phone to the answering machine. from the user Fax guide: If desired,you can also connect an answering machine or an extension telephone to your fax. ¨ Connecting an answering machine to the fax will allow you to receive both voice and fax messages on the same line while you are out. For details on using this feature, see Chapter 7. (Note: Do not connect an answering machine to your fax if you will be using the distinctive ring feature described in Chapter 2.) ¨ You can connect an extension phone to the fax to make and receive calls like any other extension phone on your line.
Oct 09, 2005 | Sharp UX 510 Plain Paper Thermal transfer...
Lands Phones Logo
46 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Thomas F. Schneider
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
