My volume keeps turning down when im not touching the control
I bought my wing 4 months ago and now the volume feature keeps turning down on me and that lil volumes window pops up. It interfers with my call and will not let me text because of it. HELP PLEASE!!!!
I'm having the exact same problem and it's driving me nuts! My wing can be sitting idle and then all of a sudden the volume turns up or down automatically. And then it will lock itself after pushing a few random buttons.
Is there a solution? Is it a virus? HELP!
I've restarted, reset, and deleted files from both the phone and my memory card.I'm having the exact same problem and it's driving me nuts! My wing can be sitting idle and then all of a sudden the volume turns up or down automatically. And then it will lock itself after pushing a few random buttons.
I have the same problem, even i had done Hard Reset more than once but it comes back again and again after a day or two.
Can anybody suggest any solutin other than just hard reset?I have the same problem, even i had done Hard Reset more than once but it comes back again and again after a day or two.
You can't post conmments that contain an email address.
Re: My volume keeps turning down when im not touching the...
Sounds like software issue, make sure you keep memory available, messaging>menu>goto>folders, check sent and deleted files. Remove any third party software, and may need to do a clear storage to reset software.
If it is nine months old the set must still be under warranty, the problem you are describing is an intermittent audio problem and can be difficult to locate. I recommend getting in touch with the people you bought it from and get the satisfaction you deserve.
On remote you must push the TV button first then the on button to activate or deactivate the TV. Channel or volume on the TV does not need to select anything on remotes.
I have had this problem since I bought my washer. Some days the tub clean cycle will work....most days it won't. They have replaced the main board twice and it's still broken. I've had nothing but bad luck with LG appliances. Also bought a lemon fridge that took 4 repairman visits to fix. I will not buy another LG anything!!
Turn the mouse over, and remove the 5th central mouse foot. Underneath is a torx screw. Remove the screw, and turn the mouse back over. At the back, there are two dimples. Between them is a seam, side your fingernail or a knife into the seam, and the top surface of the mouse should easily lift off.
Sorry All, I have had my Wing for 7 months now and never cracked or scratched the screen. I live in NYC so im always walking around in hot and cold so its not any weather condition as someone suggested, i take care of it keep it in the case when im not using it. Ive also never dropped it - yet!!!
