Fuji FinePix F410 Digital Camera Logo
Posted on Dec 18, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It is just about my camera F410
Helo sir,
As I put on the camera, nothing show on the screen which can allow me to snap. The memory card is well fixed also the battery. What could be the problem ?
Thanks
Ola
[email protected]
As i put
CameraR
Level 3:
  • Fuji Master 4,738 Answers
  • Posted on Jan 05, 2008
CameraR
Fuji Master
Level 3:
Answers
4738
Questions
Helped
1194573
Points
12483
This sounds like it might be a defective CCD imager. If so, Fuji should fix this for you for free. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/12/fuji-digital-cameras-showing-black.html
http://www.fujifilmusa.com/JSP/fuji/epartners/ServiceSupportProductContent.jsp?dbid=839010&prodcat=2147483647&sscucatid=664262&quicklink=true
Applicable cameras include:
F303, F410, and F700
My camera suddenly the screen can not show the picture ...
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
1helpful
Nikon Coolpix will not show up on iPhoto
Consider connecting a card reader instead of a camera to your Mac.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader. This is likely to be faster than connecting the camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
2answers
I just bought one, every card I put in it it tell me the card is full, insert new one
Remove the memory card, now! if you have used the internal memory even once, go to menu and select "format" follow the on screen prompt to erase the data, now install the memory card it should allow you to take photo's.
1helpful
I have a problem with my camera (Fuji F410)- lens will not retract and I get 'focus error' on screen. Manual suggests turning on and off, but this does not cure the problem.
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Sd card locked showing on camera
dear sir,
remove the memory card,and just push the push button at the upper side of the card which allows the card to lock and unlock.....kindly unlock it and put inside camera and your flash disk is no more write protected...
thank you......take care......
Hello sir my sanyo digital camara S4 not detect sd memory. when i put memory asking format if press ok nothing hapen then coming mesege no image what hapen?/ help me withou memory camera is ok
Formatting the memory card according to rhe camera's supported format should fix this. If after formatting and did not work, it means that the memory storage device is faulty. You have to replace your memory card with a new one to make take and save pictures again.
Jun 01, 2010 • Cameras
I buy a wespro dv 532 digital handy cam its memory show full but i buy new sd 2gb memory card its also show memory full pls send me detail how to use memory card and save snaps/video in memory card please...
Dear Sir,
I (Madhuhas Sharma) bought a handycam ( DV-532) from Naptol .com at 5th Oct 2009 . but since 7th Dec 2009 my handycam show the display problem . I call many chance to tolfree no. but they did not satisfy to me so please sir solve my problem we thanks whole life . i can do a mail before at 22nd december2009
Fuij FinePix F410 Digicam
Hey mtangobung,
What this prompt means is that your memory card needs to be formatted, or the memory card contacts have somehow gotten soiled and the camera is not detecting the memory card. I would first try formatting the memory card in the camera, but remember this will erase all the images on the card so upload any images on the card to a computer first. If reformatting doesn't work I would clean the memory card contacts with an eraser. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
1helpful
2answers
My F410 ceased to take photos
2answers
Digital camera faulty
The Dark LCD can mean the backlight has gone down- no repair option here. or A connector to the board has come adrift- Are you sure there are no images being made - have tried? As a try take the camera firmly in your paw and squeeze or flex the casing at the base of the screen area.-This is where the connectors are You make get a re connection. Also tell Fuji Tech Support about this
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
