The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
SOURCE: date/time/resolution problem w/ Ex-S500
There ccan be 2 problems that cause this. First most backup memory us powered by a button battery. They can be hidden and sometimes had to locate may require a fingernail to lift a panel. On the cano cameras its under a little door where the USB plugs into. Second could be the amout of time between use. Some may use a little cap with is like a small low voltage rechargable battery. If the camera has been sitting a few weeks its possible the little cap is draining over the time its not in use. You may have to dig out your manual to see if it says anything about a button battery. Or you may need to call casio There is a firmware update for your camera located on the casio site that fixes some problems maybe this is one of them? it wouldnt hurt to update your firmware because it fixes someimage quality issues. Remember to recharge your batterys first before you do it. Read the warnings
SOURCE: Casio Exilim EX-S600 time and date entry at every startup
Even casio seem confused by this question! It seems that the camera will loose it's settings if the battery is dead or the camera is not connected via USB. Even if the battery is charged it could loose the settings within 24hrs. You can get the manual below: http://world.casio.com/qv/download/en/manual/
SOURCE: Casio ex-z500 jammed with lense
I have just experienced the same problem with the lens jamming. I bought it for my wife having been impressed with the EX-Z500 my daughter bought. She had the same problem last year and paid for an expensive repair, then I found that her partner's sister had also bought one and.......you've guessed it...the lens jammed on that one too.
So that's another three Casio EX-Z500 digital cameras to add to your list of Casio generic lens jamming problems.
SOURCE: Have Casio Exilim EX-Z750, 4 yrs. old. Every time
read the manual again. and reset to automatic update
