THANK YOU for your purchase of the M100 GameSpy Digital Camera. Please ... The Mode Button selects the 3 modes of the camera - Camera Setup Photo Review or ...Accepts the Moultrie PowerPanel accessory (sold separately) only. ... Camera operates in Plot Cam mode during the day and Trail Cam Mode during.
Walmart
Rating: 4.5 - 21 votes
MOULTRIE Game Spy M-880 Low Glow Infrared Digital Mini Trail Game Camera ' 8 ....You can easily hold this mini IR camera in your palm. ... MFH-DGS-M100 .... Will ittake pictures only on motion detection? ... can get any size you want but don't forgetyou will have a lot of photos to delete. ... A. Will do video clips and stills.
Does the flash work? Could be flash circuit or day/night sensor.If you have another D40/D50 camera that flash works but has other problems,swap out the sensors.If not the sensor but the flash circuit then most likely one of the large charge capacitors which has to be soldered in.I use a digital multimeter with I/O capacitor test function..these caps should be about 250mfd.
1) This camera accepts SD cards up to 4 GB in capacity. Most 4 GB SD cards however, are "SDHC" types (check the label to determine which type you are using). If you are using a 4 GB "SDHC" card, it may be causing the problem, as it is not an "SD" card. Furthermore, any card greater than 4 GB is not compatible with the camera. Any SD card with a capacity less than 4 GB should work without issue.
2) Check the position of the lock or "protect" tab on the side of a compatible SD card to be sure it is in the unlock position. The camera will be unable to write to a locked or protected card.
