It's a little fiddly:
1) Remove the battery cover
2) Remove the 4 screws on the transceiver board
3) Unplug the 2 flex cables, coaxial cable and earpiece cable from the board.
4) Remove the transceiver board
5) Remove the rubber plug and antenna cover from the rear lower of the handset
6) Remove the 2 screws under this cover
7) Carefully unclip the bezel from the phone and remove it
8) Unclip the 6 clips holding the display bezel in place from the back of the phone - you need to use a thin screwdriver in the 6 slots (4 of them are under where the transceiver board was, the other 2 are in the batttery compartment.
9) Lift the display and frame away from the chassis.
When reassembling:
Make sure the keymat is correcly located on the pins on the front bezel
Ensure the earpiece cable is in the right place, and not trapped.
Be careful reattaching the cables to the transciever board - they are both small and fragile.
