Just insert any nice pin on the hole seen below the drawer\
Good day sir/maam, first things first, make sure that the power connector of your CD/DVD drive is properly connected, if improperly connected may cause the tray not to eject. Now lets proceed to your problem, there is small hole in front of the cd/dvd drive which is used to eject the tray, use a paper clip, straighten it and poke the inside, feel the eject button. until your tray eject. thats it.
Does the light flash when you press the button? If so, was there a disk in the drive previously? There is a small hole on the front of the unit. With power off, get a paper clip and open it up halfway. Push the open end into this hole and the drawer should pop open by about half an inch. This will be enough for you to gently pull the drive open and remove anything stuck inside. Ian.
SOURCE: cd rom disk drawer will
by your cd/dvd drive. look for a tiny hole that looks about the size of a thickness of a paper click which you will need to unfold 1 and insert the tip into the hole and gently push forward and it should pop the tray open .
