Expert
- Posted on Sep 29, 2009
Re: motor locked up during use pull string will not move
Sounds like your engine overheated and is siezed. Remove the exhaust muffler and inspect the piston, it should be shiny and oily. You will see if the piston is scored or if the ring is siezed. If this your problem you can replace the piston and cylinder, but it could be expensive. Stephen.
