Maytag washing machine want spin without clothes getting out of balance and then the washer walks across the floor. What causes this
clothes appear to work to one side during spin cycle causing the washer to get out of balance. Clothes are balanced when washing cycle begins.
Did you set the back feet before leveling? On most units to set and lock the back feet you need to pull the top towards you so that the back is raised off the floor, then set it down again, this will release the feet and lock then down. The you level the two front feet. After this is done you must make sure your load is balanced. Distribute the items as evenly as you can in the tub. Once it gets to the spin cycle if its walking or shaking a lot, stop it and redistribute the items more evenly in the tub. Also try not to overload the unit or combining many heavy items with few light ones. If this is a new machine, did you remove the shipping locks from the back before using it? They have plastic strips attached to them, make sure they have all been removed, as well as any shipping bolts.
This model of washer does not have an out of balance cut off switch. If the load is not balanced properly the tub could hit the cabinet sides. If the unit spins evenly while empty & out of balance while loaded, I recommend checking & balancing the load. If the basket spins out of balance while empty, I recommend having the suspension springs & balance ring checked. Be sure not to wash light fabric with heavy fabric clothes. Also ensure that the adjustable feet are level, that's most important.
the machine is not level... put a level across front back sides to check adjust legs leveling bolts as needed.... also is the machine installed on a carpet floor??? if yes put a sheet of plywood under machine so it wont "bounce" on floor.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. ----------------------- The problem is the brake. The odd time what happens is moisture gets on thebrake rotorand the squealing is heard when thebrake statoris applied to stop the tub from spinning. This moisture, may drip down from the tub onto the brake rotor which could indicate a leaky tub seal. If you can't see any dripping when you fill the tub with water, don't worry about the tub seal. Many times than not the brake is just going sour on it's own. Sometimes you can fix the squealing by cleaning the rotor and stator with a light sandpaper, such as emery/sand cloth. If that doesn't work you will need to replace the brake stator and rotor. If you need to replace them replace both parts together, don't just change the stator without also replacing the rotor, or vice versa. And here's a bonus tip: the brake spring exerts 200 pounds of force. If you try to remove the six 5/16" screws without using thisbrake removal tool, serious injury can/could happen!! The splined part in the middle of the brake needs to be greased really good before putting the brake back on!
Typically when the drum spins and walks the washer, it is a loading issue. As the clothes spin, they collect on 1 side, due to cintrifical force acting upon an uneven load. THis is especially prevalent in loads that are: 1. small, 2. contain lots of towels and 3. anything else that really holds water and is very heavy when wet (like comfortors, pillows)
These will very quickly throw the load off-balance.
When it happens, pull out some of the itmes, and re-load the laundry more evenly around the drum. Be sure to circle the post with towels and sheets, etc.
If you continue to run the machine off-balance for an extended time, the bearings and seals will wear quickly. Unfortunately, you will only know this when the washer begins to leak out under the machine onto the floor.
Hopefully this will fix-ya....if not let me know please!
This machine uses an auto-adjust for the back portion and they tend to get stuck. Since it sits on a common chassis, insert two standard legs in the back. There are threaded holes that the legs go in. Rebalance the machine. Your problem should stop.
I have had teh same problem. I calledin the Maytag service and they did replace something out of goodwill but the technician told me that the load balance sensor is sensitive. If your load is unbalanced then the machine will spin slowly so it does not walk across the floor. With larger loads the wieght will make the machine bang against the sides and walk.
The solution is quite simple. Make sure the load is balanced. The agitator has a way of unbalancing a load from time to time so you need to do this manually. It is a very rare occurance and it is best to make sure your load goes into the machine balanced first.
during spin cycle the clothes pile to one side causing unbalance in washer
