Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x Logo
Posted on Sep 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Gas flows freely out the carborator pn 632351 on a tecumseh 8hp
Gas flows freely out the tecumseh 8hp carborateor pn 632351
daniel timmons
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 153 Answers
  • Posted on Sep 27, 2009
daniel timmons
Expert
Level 2:
Cheetah:
Answers
153
Questions
Helped
70882
Points
327
Needle and seat valve stuck open remove float bowl and find the cause
1helpful
My 8hp Tecumseh jumps in and out of drive as Im snowblowing. Have to pull it back and forth and sometimes jerk it around to get it to kick back in. Any advice?
which blower is this on?
sounds like the drive wheel is worn or out of adjustment
or you could have worn bushings on the axles or grease on drive plate
be sure gas is less than 1/2 full
tip it on its nose remove plate on bottom and inspect
Tecumseh 8hp drive stopped have to push
Could be the belt is broke or come off or the pully loosened on the shaft. Good Luck
Fuel tank for 8 hp tecumseh mtd chipper shredder
There's a website that ha s all this information about all this and manuals everything totally free there are many actually but I personally like few .. let me know if u need help
thanks
Honda 8hp motor only starts with quick-start fluid
if you have gas to carb rebuild carb or relace
1helpful
My snowblower Yard Machines 26" 8HP started but
Clean the carburetor and check the intake manifold to the head for air leaks/bad gaskets.
I HAVE A TECUMSEH 10 HP ON AN AIR COMPRESSOR IT STARTS, BUILDS AIR PRESSURE THEN IT SHUTS OFF INSTEAD OF GOING TO LOW IDLE
try to decrease regulator, maybe you ask to much power and it shuts of. specially with cold motor its important to ask less pressure.
1helpful
2answers
I have a vm80 8hp tecumseh engine 150092D day
If you want a 'drop-in' replacement, you will HAVE to source a carb that was fitted as original equipment. Following the demise of Tecumseh's engine division, supply is limited to 'old stock', but there is fair spares aqvailability at present. A newer 'primer start' carb will fit, but you will have to remove all the choke operating mechanism. Don't fit a carb from a larger or smaller engine - the mixture will be wrong, and the engine will never run properly.
Sep 25, 2009 • Garden
Timing this engine a1974 tecumseh 8hp
if this is a single cyl engine ,the timing is correct when the match marks on the cam gear and thecrank gear are lined up .
1helpful
Electric start not working 8hp.mtd. snowblower
Hi, check the starter if it's engaging too the flywheel. there is plastic molded gear on top of your starter some times gets broken.
If this doesn’t work for you please write back. Thanks,
Nov 21, 2008 • Garden
Top Tecumseh Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Tecumseh Tool and Hardware - Other Expert? Answer questions, earn points and help others
