Ricoh Aficio CL2000 Laser Printer Logo
Posted on Dec 17, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ricoh Aficio cl2000
First there were streaks of no printing on one side, now printing a black test page results in a little printing on the left, none in the middle, and very little on the right. Black cartridge is new and pretty full. The streaks remain. Color seems to be OK.
  • rcos Jan 08, 2008
    I have the same problem with a CL3500 model. Does some part need replacing?
  • bwacker Jan 13, 2008
    Mine turned out to be the black drum, a slide in/out part. Apparently the drums are designed to have a limited lifetime. If colors are a problem, then the three color drums come together as a separate unit.
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Dec 05, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4535
Points
8
Most of the time when I find this happening on a printer, not just Ricoh's it turns out to be the PCU (photo conductor unit). The color PCU is one unit and the black is a seperate unit. Hope this helps.
Anonymous
Level 2:
  • Expert 417 Answers
  • Posted on Jan 13, 2008
Anonymous
Expert
Level 2:
Answers
417
Questions
0
Helped
362379
Points
739
The following is taken from the service manual I hope it helps thanks J
4.3.1 BLANK PRINT
Symptom Possible cause Necessary actions
Defective laser scanning unit Replace the laser scanning
unit.
Defective PCU Replace the PCU.
Defective transfer belt unit Replace the transfer belt
unit.
tension unit
tension unit.
Defective toner cartridge
drive unit
Replace the toner cartridge
drive unit.
agitator
Replace the toner cartridge.
Incorrect action of transfer
roller
Check the guide and the
transfer roller.
Defective high voltage
supply board
Replace the high voltage
supply board.
No image is printed.
Defective engine control
board
Replace the engine control
board
4.3.7 WHITE HORIZONTAL LINES OR BANDS
unit.
White lines or bands appear
in images of all toner colors.
They are vertical to the
paper feed direction. Defective transfer roller Replace the transfer roller.
4.3.8 MISSING PARTS OF IMAGES
unit.
Some parts of images are
missing.
Defective fusing unit Replace the fusing unit.
4.3.11 DARK IRREGULAR STREAKS ON PRINTS
Unexpected streaks appear
at irregular intervals.
Defective transfer belt Replace the transfer belt
unit.
4.3.17 NO PRINTING ON PAPER EDGE
Defective toner cartridge Replace the toner cartridge.
unit.
images are not printed in the
areas around the paper
edges.
Transfer belt not contacting
PCU
Check the belt tension unit.
Try these hope I could help Thanks J
My Ricoh Aficio CL2000 suddenly only prints half of the (photo)page.
publib.boulder.ibm.com/infocenter/iseries/v6r1m0/topic/clpdf/SS1-6.pdf
2helpful
Where is the black photo condutor on Richo Aficio CL200N located?
I found the manual for your laser printer courtesy of Ricoh:
http://www.ricoh-usa.com/downloads/manuals/printers/cl2000.pdf
Page 5 of the PDF manual talks about the black photo conductor and where its located at.
1helpful
2answers
Balck and white streaks on left side of paper
Usually if there are streaks you need to change the pcu that is the same color as the lines. If the streaks are gray it also could be the fuser, but i would think it is the pcu.
2answers
Add Black Toner Msg.
Try taking out the cartridge and reinstalling it. Was this a original ricoh toner cartridge or a el cheapo cartridge off the internet?
Black smudgy streak in middle of printed page
if you need any parts for that machine a have 4of them
Thank You,
Mikey
Ricoh Aficio CL 2000N printing problems
If the colors are good and solid with no fades, only black streaks, then black is the culprit. I suggest replacing the black cartridge.
2answers
Color Streaks down length of page
My rep advised that if this problem is occuring when using the feeder, the small glass strip to the left of the glass can have some sort of either high lighter or white out stuck to it. He suggests cleaning this with some alcohol.
Black lines (streaks) printing on left of page on my ricoh 2000n
Running cardstock lightly misted with water or dilute cleaning solution through several times can help. Use either the feed button or print using a program that allows you to print blank pages.
4helpful
3answers
Error Message: Replace Black PCU
I'm not sure how to obtain one, but "Black PCU" stands for Black Photoconductor Unit, and according to a manual for a different Ricoh printer model, it should be fairly simple to replace if you can find one.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
