Bissell 3102-0 EasyVac Upright Vacuum Logo
Posted on Sep 26, 2009
Wont sweep up after I emptied.
I have a bissell easyvac bagless. My son threw away my manual. I emptied it once and I can't get it to work right again. I think it just needs to seel correctly, but I can't tell how to with out a manual. thank you Jeanel
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Feb 03, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
2953
Points
10
The website www.bissell.com lets you look up your manual and even save it if you like. That's how I fixed mine. Just type in your vac type under troubleshooting and it will let you choose the manual based on the model number and each manual has a section for troubleshooting and how to fix each possible problem. If none of those troubleshooting tips work, you can always call bissell at 1-800-237-7691. Hope this helps!
I have a bissell steam and sweep. when I am finished using it water still leaks from the bottom leaving water?
  • Drain the tank after each use.
  • It either has no shut off valve or a broken one when not in use.
  • If its new return it and see if new one leaks or not.
My Bissell easyvac is nolonger picking up rpoerly, I cannot find the user manual. What can I do?
You can download the user manual from the manufacturer's web site at
http://www.bissell.com/DownloadAsset.aspx?id=577
Bissell easyvac filters
Replace Filter
As you vacuum, dirt and debris are deposited in the Dirt Cup
while air passes through the filter before being returned to
the room. This process enhances the vacuum path while
dramatically reducing dust, dirt, and potential allergens from
the air you breathe. Replacing the filter periodically enhances
vacuum power and air quality. To replace the filter:
1. Remove the Dirt Cup.
2. Grasp the filter frame and pull it straight from the Cup.
Empty the Cup.
3. Replace the filter. Push new filter into place at the top of the
Cup, place the small tab at the bottom of the Cup into the
slot at the bottom of the Canister cavity, then press the upper
portion of the Cup into place until the lock button snaps
into place. Use only BISSELL Style 6, #32047 Filters
[package of 2] in your BISSELL EASY VAC™ Model 3101-0.
4. EASY VAC™PLUS Model #3102-0 features a high efficiency
3M Filtrete™ Filter. To keep your cleaner operating at peak
efficiency and to remove irritating allergens from your
home, you should change the FILTRETE™ filter every six
months. Use only BISSELL Style 6, #32046 Filters [package
of 2]. The cup-shaped filter lifts out from the top of the
Dirt Cup, and the new one fits into place.
You may purchase these filters
by calling
BISSELL Consumer Services
1-800-237-7691
Monday - Friday 8 a.m. — 7 p.m. EST
Saturday 9 a.m. — 2 p.m. EST
or from the BISSELL website —
3helpful
Bissell easyvac 3108.No suction.Changed filter/cup.Brush working fine.
I had the same problem, ended up I had to clean out the hose for the accessories...I found out how to do it by looking at the troubleshooting section of my owner's manual online at bissell.com. (Just type easy vac under troubleshooting and choose the instruction manual based on your model number). If none of these things work, you can always contact bissell at 1-800-237-7691. hope this helps!!
1helpful
Bissell easy vac plus
Press the lock button down and forward (away from the
Canister Handle) while lifting the upper portion of the Dirt Cup
away from the Canister. The bottom box should then come out.
If you need a user manual for this model I have one and can send it to you if you email me.
2helpful
Need filter, bissell 3102-0 EasyVac
The filters can be found on GoVacuum.com for 11.90 with free shipping
My Bissel stopped working and have no clue why?
Try Bissel .com, maybe you can download a manual from there. But if it just quit, the cord maybe bad. Alot of times if you unplug the cord by pulling on the cord rater then the plug, you cause the wire to eventaully break. That would be the first thing I would check. ( I am assuming that your vac just went completely dead.)
Top Bissell Vacuums Experts
Mike Cairns
Mike Cairns
Renee Knafel-Bullock
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
